Marxon Posted December 31, 2010 Report Share Posted December 31, 2010 (edited) Hi all, i do not really understand the pattern change behavoir in the drum kit 2 patch. To play pattern 1 i push O1 Pitch, to play pattern 2 i push O2 Pitch -> erveything OK But doing a pattern change from pattern 5 back to 1 then the resulting pattern change seems to depend from the actually step which is playing? May i missed something, but i searched the manual and forum about this without succsess. Can someone explain it to me, please? Best regards Marxon Edited December 31, 2010 by Marxon Quote Link to comment Share on other sites More sharing options...
TK. Posted December 31, 2010 Report Share Posted December 31, 2010 Maybe you are playing one or more keys on an external keyboard at the same time? Because pattern changes are not only controlled by the matrix buttons, but also by received MIDI Note On/Off commands. To doublecheck that this behaviour isn't related to a hardware issue, I would propose to unplug the MIDI IN cable after you've ensured that there is no actively played MIDI key. Alternatively you could select another MIDI channel and/or reduce the keyboard zone for the drum instruments (ENS->INS) Thereafter press and depress the PLAY button - this will initiate an internal "all notes off" - just to ensure. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted December 31, 2010 Author Report Share Posted December 31, 2010 Hi TK, first: i was wrong it happens on pattern 6 not 5. No matter how they are played (via midi keyboard or matrix buttons) or if the midi cable is plugged or not. The changes are not randomly: Changing to pattern 1 at 1/4bar = "pattern 1a" Changing to pattern 1 at 2/4bar = "pattern 1b" Changing to pattern 1 at 3/4bar = "pattern 1c" Changing to pattern 1 at 4/4bar = "pattern 1d" also Changing to pattern 2 at 1/4bar = "pattern 2a" and so on.. Quote Link to comment Share on other sites More sharing options...
