padjoe.thornton Posted March 9, 2011 Posted March 9, 2011 Hi everyone I'm really enjoying this project Great forum with nice people I have built http://www.ucapps.de/mbhp/mbhp_8xsid_c64_psu_optimized.pdf and am using 2 sid one core I'm connecting the modules firstly to a safe power supply where im going to power it up and if there are any shorts it will tell me, I wanna do this to be safe with the circuit, and so I can Identify any problems before I use the C64 PSU I'm using the newer SID chip the 8580 and using a C64 power supply that came with the newer C64. I'm finding it difficult to identify all the PINs especially PIN 6 coming from the C64 PSU and into the socket and into the power switch on the left of the diagram. I'm taking it that PIN 7 is 9VAC, PIN 2 is Ground, and PIN 5 is 5VDC Here is a schematic of the C64 power supply http://www.zimmers.net/anonftp/pub/cbm/schematics/computers/c64/c64extps.gif This is probably a complete Newbie question but I just want to be sure Thanks in Advance PJ
Imp Posted March 9, 2011 Posted March 9, 2011 Hi PJ, as far as i know, all versions of the C64-psu had the same pinout. So, pin 6 is located as shown in that picture. It doesn't matter, if you exchange pins 6 and 7, because the AC they deliver gets rectified afterwards. You can see that in the pdf: those diodes marked "X1" are the same for both lines. To identify pin 5, just use a multimeter.
Wilba Posted March 9, 2011 Posted March 9, 2011 Also, sometimes a C64 PSU has the 5V pin on the other side of ground. It is safe to connect both those pins together on the socket side (this is what I did on MB-6582 PCBs).
