Echopraxia Posted June 1, 2011 Report Posted June 1, 2011 (edited) Really sad to part with her. MB-6582 is complete minus 3 of the 4 gang pots on the back are not mounted which only affect the sound a tiny bit and just add a little bit of distortion. I have the other 3 and will include them along with 2x spare 6582 sid chips and a spare cs pcb. Besides that the left side of the lcd display still needs to be mounted but the right side is mounted so the lcd just has a slight downward slope to the left where its at now. Works great and the lcd works just as everything else works. Fully stuffed 8x 6582 sids, panel, pactec case, everything. You can take this home and hook it up without any fuss as its ready to go and fully functional. You will need stereo TRS 1/4" to 2x mono 1/4" TS cables to get stereo out of each sid pair ( this is how the unit is designed) Lava cable can make them for you and I strongly recommend you buy all your cables from them regardless. One last note, the data encoder currently does not have a 1:1 click:increment so when you turn the data encoder 1 click it will advance 3-4 steps instead of the intended 1. This can easily be fixed by going in to the text file and changing the encoder type and reloading the firmware. Selling for cost of parts + shipping. PM if interested. I am including a c64 power supply as well. Edited June 1, 2011 by Echopraxia
