toneburst Posted July 21, 2011 Posted July 21, 2011 Something I've noticed: none of the presets that come with the MB_FM application seems to respond to MIDI velocity. Am I right in thinking that velocity can only be mapped to a single parameter, on a per-INS (instrument) basis? I guess this means that you can have velocity set the overall volume of a note (by mapping to carrier amplitude), or change the timbre of a note (by mapping it to amplitude of one of the carrier operators), but not both. Or is there a way of doing both things at the same time? The drumkits also don't seem to respond to velocity, and I can't seem to find any parameters for making them do so. Am I missing some global parameter to enable velocity-sensitivity, or do the drum sounds just not have the capacity to respond to velocity data? a|x
