findbuddha Posted July 30, 2011 Posted July 30, 2011 TK, can you please check the schematic in mbhp_blm_map.pdf? In the extra row, buttons 9-16 have the LEDs mirrored in their groups of 4 with respect to the switches. To explain another way, on my PCB, if I push button 9, LED 12 will light, and vice versa. Also, could you please offer some guidance as to how I should modify the scalar app(MIOS32) to remap these? This PCB is 5x17 version of the full BLM16x16, just to use for buttons for a mixer section ie. mute, solo, arm etc. So I won't need the 'packed format' pattern matching, just toggling of specific LEDs on MIDI in and button push. I suspect I need to do my remapping in this function: if( note <= 0x0f ) { // BLM16x16 LEDs led_mod_ix = chn >> 2; led_row_ix = ((chn&3) << 1) + ((note >> 3) & 1); led_column_ix = note & 0x7; modify_led = 1; } else if( note == 0x40 ) { // extra column LEDs led_mod_ix = 4; led_row_ix = (chn&3) << 1; led_column_ix = chn >> 2; modify_led = 1; } else if( chn == 0 && note >= 0x60 && note <= 0x6f ) { // extra row LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = note & 3; modify_led = 1; } else if( chn == 0xf && note >= 0x60 && note <= 0x6f ) { // additional extra LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = 4 + (note & 3); modify_led = 1; } and also maybe in DIN_BLM_NotifyToggle depending on what MIDI feedback I can get Reaper to give me. Thanks :)
TK. Posted July 30, 2011 Posted July 30, 2011 This is very strange, because the LEDs and buttons should be connected to the same common lines (blue lines in the mbhp_blm_map.pdf file), accordingly there is no reason why the LEDs should be mirrored. Could I have a look into your PCB layout? Modification: // extra row LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = note & 3; if( note >= 0x68 ) led_column_ix ^= 3; // mirrror LEDs 9..12 and 13..16 modify_led = 1; [/code] Best Regards, Thorsten.
findbuddha Posted July 30, 2011 Author Posted July 30, 2011 TK, As far as I can tell from the schematic it's not the cathodes that are swapped but the LED anodes. (I think that is the correct terminology) Comparing extra row buttons 1-4 and 5-8 with 9-12 and 13-16, for eg. Switch 1, 5, 9, 13 -> I0 Red 1, 5 -> R0 Green 1, 5 -> G0 BUT: Red 9, 13 -> R3 Green 9, 13 -> G3 I've attached an image of my PCB which I think is consistent with the schematic. I'll have the full design files up on my wiki page once I've got this sorted. Also, I realised that for this PCB I'll need to mod the following section, as I don't have the full chain of BLM_SCALAR preceding the +X section. I'll have to have a think about it. // BLM16x16 LEDs led_mod_ix = chn >> 2; led_row_ix = ((chn&3) << 1) + ((note >> 3) & 1); led_column_ix = note & 0x7; modify_led = 1; Thanks heaps :) :flowers:
TK. Posted July 30, 2011 Posted July 30, 2011 Ah - now I got it, and corrected the schematic! I'm sorry that this mistake caused trouble at your side! :-/ Best Regards, Thorsten.
findbuddha Posted July 30, 2011 Author Posted July 30, 2011 No worries - thanks for all your hard work :)
