Hello,
I would like to avoid MIDIOX for mapping the output of the Midibox-cores, so I think of modifying the program "Sending MIDI events on button movements" (/Ucapps/Programming/MIOS 8 C Interface). I understand that modifying this way would do the trick for configuring the channel:
MIOS_MIDI_TxBufferPut(0x90); // Note Event at channel #1
MIOS_MIDI_TxBufferPut(0x91); // Note Event at channel #2
MIOS_MIDI_TxBufferPut(0x92); // Note Event at channel #3
etc
But I need also to set first note number to 36, and thats my question. I suppose it is from general interest, since many musician use anyway 5-octaves-keyboard.
If I modify
MIOS_SRIO_NumberSet(16); // for 128 pins
this way, I suppose I'll get the notes 0-63
MIOS_SRIO_NumberSet(8); // for 64 pins
So I understand I must set the value of 36 as first note number in the DIN_NotifyToggle part of the program, is it the right way to write:
void DIN_NotifyToggle(unsigned char pin, 24) __wparam ; // 24 ist hex for 36
or must it be:
void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam
MIOS_MIDI_TxBufferPut(0x24); // begin with pin #36
MIOS_MIDI_TxBufferPut(pin); // just forward the pin number (36..96)
MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); // Velocity = 0x7f when
// button pressed, else 0x00
Or something else? Excuse me, but my notions of programation are very basical...
Thanks in advance,
Francois
// This function is called by MIOS when an button has been toggled
// pin_value is 1 when button released, and 0 when button pressed
  MIOS_MIDI_TxBufferPut(pin+offset);  // just forward the pin number (0..127)
in which
offset
is the transposition you want to apply. E.g., if you want your notes to be played one octave higher, then offset = 12.
Hope that helps, ilmenator
