tupinamba Posted August 27, 2011 Posted August 27, 2011 Hi, I first posted this question in another topic and I think this was a bit confusing... So: in SONG MODE, is there a way to tell the sequencer to repeat a certain pattern endlessly until manually told to move to the next song step? Then your solo can last until you or your audience get bored... :shifty: Thanks!
TK. Posted August 27, 2011 Posted August 27, 2011 Yes, there is a way: use phrases (16 phrases are available per song). Example: Pos Actn G1 G2 G3 G4 A1 x 1 1:A1 2:A1 3:A1 4:A1 A2 x 1 1:A1 2:A2 3:A1 4:A1 A3 x 1 1:A1 2:A3 3:A1 4:A1 A4 x 1 1:A1 2:A4 3:A1 4:A1 A5 Jump Pos A1 [/code] This will loop between Song position A1..A4 Now create a second phrase, starting at B1 [code] Pos Actn G1 G2 G3 G4 B1 x 1 1:A1 2:B1 3:A1 4:A1 B2 x 1 1:A1 2:B1 3:A1 4:A1 B3 x 1 1:A1 2:B2 3:A1 4:A2 B4 x 1 1:A1 2:B3 3:A1 4:A2 B5 Jump Pos B3 When the sequencer is playing, you are able to switch between phrase A and B with the GP buttons Note that you can also add a mixer map (for sound settings/program changes/volumes, etc), Mutes and Tempo to a phrase: Pos Actn G1 G2 G3 G4 C1 Mixer Map 1 C2 Mutes oooo oooo oooo oooo C3 Tempo 132 BPM C4 x 1 1:A1 2:C1 3:A1 4:A1 C5 x 1 1:A1 2:C1 3:A1 4:A1 C6 x 1 1:A1 2:C2 3:A1 4:A2 C7 x 1 1:A1 2:C3 3:A1 4:A2 C8 Jump Pos C6 [/code] Best Regards, Thorsten.
tupinamba Posted August 27, 2011 Author Posted August 27, 2011 Wow, that's great! Each day comes with another possibility unravelling to me... Is it ever going to stop? :smile: Thanks again Thorsten.
tupinamba Posted August 27, 2011 Author Posted August 27, 2011 (edited) ... OK, one more time :blush: In PHRASE MODE, it looks like it doesn't automatically go from song position A1 to song position A2 (unless A1 is TEMPO, MUTE, etc...). i.e. it repeats the same pattern, unlike in the exemple you gave me where you created a loop from A1 to A4 and all that made a phrase. Is there something to set up? Edited August 27, 2011 by tupinamba
TK. Posted August 28, 2011 Posted August 28, 2011 You are right, I overlooked this. In the next version it will be possible to change between phrases in song mode as well. With the changed behavior it will work for your usecase Best Regards, Thorsten.
tupinamba Posted August 30, 2011 Author Posted August 30, 2011 Thanks Thorsten, this is great news. All the Best, Gaël
tupinamba Posted February 11, 2012 Author Posted February 11, 2012 Hi Thorsten, Is there anything new on the subject ?... And something else : is it possible to repeat a 16-step-long fragment of a long pattern (128 for instance)? When composing it would make things easier when you can hear the portion you're working on as a loop... Thanks!
TK. Posted February 11, 2012 Posted February 11, 2012 Thanks for the reminder - I wanted this feature as well, therefore I will implement it tomorrow. :) And something else : is it possible to repeat a 16-step-long fragment of a long pattern (128 for instance)? yes, just enable loop mode with MENU+SCRUB This mode can be configured in the Fx->Loop page, e.g. it's possible to loop only the step view (16 steps) of the currently selected track, or all tracks. And the loop length can be configured as well. Best Regards, thorsten.
tupinamba Posted February 11, 2012 Author Posted February 11, 2012 Great ! And great ! :thumbsup: Thanks again (and again) Thorsten ! Cheers,Gaël.
tupinamba Posted February 15, 2012 Author Posted February 15, 2012 (edited) Yesssss ! ! ! I think that's worth a beer... :thumbsup: Edited February 15, 2012 by tupinamba
