Broken menu button
Waffa
Hi all!
Just finished my sammichSID :frantics: and everything works except the menu button.
-Multimeter says no power on S10, the buttons 9,11,and 12 work perfectly. How to fix this problem?
-All the buttons have a power reading 4,95 V, but the S10 only measures 0,08V.
-Soldering seems to be solid, the button itself seems to be ok. Who has a clue?
Where to start debugging?
Cheers!
Waffa
Edited by Waffa
Link to comment
Share on other sites
Thanks Janis1279,
But after inspection I see no cracks in the copperlines nor solderconnections which can shortcut.
Could it be that the 6 Pin Common Bus Resistor Networks 6PIN 10KOhms 2% is a little dead? Or is there a way to bypass s10 to toggle menu in a way?
After removing S10 my Sammich won't boot in a proper way anymore!
Cloning slaves
It says
Cloning Slave 01
Adress 0
What is wrong?
Cheers!
Edited by Waffa
Link to comment
In the MBsid_v2 user manual you can read about your sammichSID strange boot in ,
"the firmware saw "pressed MENU button :
"bullet.gif Updating Firmware to a new Version
Thats easy: just upload the new midibox_sid_v2 release to the master core with MIOS Studio.Once this firmware is booting, and the version number is displayed, press&hold the MENU button of your Control Surface to "clone" the new firmware to the slaves via CAN interface."
You can measure every resistor resistance for the 6 Pin Common Bus Resistor Networks. In the worst case not so hard to add an additional separate 10KOhm resistor, I think.
Regards,
Janis
Link to comment
Guest
Reply to this topic...
