Ian_Hurlock Posted September 22, 2003 Posted September 22, 2003 Ok so I have filled the table for pan events from enc's on channel 1 and 2 by using  00xb0 and 00xb1 this works ok and the messages appear on the channel as expected. Ie channel 1 and then 2 .So i input 00xb2 so i can get messages out to channel 3 but it does'nt seem to work and gives channel 1.If I change it to 00xb3 iget messages on channel 4.I just can't get channel 3.Do I have the wrong hex for 2 ??Any suggestions ?Ian
Ian_Hurlock Posted September 22, 2003 Author Posted September 22, 2003 I have a suggestion.After you have continuously dumped edited .syx files into your PIC it gets confused.I stuffed a fresh mios into the thing and it started to react.Now I have channel 3 from 00xb2 ;D ;DIan
Steven_C Posted October 9, 2003 Posted October 9, 2003 After you have continuously dumped edited .syx files into your PIC it gets confused. I stuffed a fresh mios into the thing and it started to react. Now I have channel 3 from 00xb2 Hey Ian, nice to see you replying to your own posts again! Thanks for the tip... I reckon it oughta go into the FAQ, under "why does my pic act wierd" or something like that!
Ian_Hurlock Posted October 9, 2003 Author Posted October 9, 2003 Hey SteveYep perhaps you are right.If I knew more about the MIOS thing I would write the dummies "how to" for it ;) ;)On that note............have you figured how to use encoders with the 64 port. Are you makin a 64 ?Every time I try to put things in for encoders it screws up the whole lot.Might have to wait till 64 has learn for enc's on it.Or go back to pots......wash out my mouth.LaterIan
