igi Posted December 28, 2011 Report Posted December 28, 2011 Hi! I have two questions about SeqV4.054 (LPC core). 1. When I enabled MSD USB everything is OK, until I try change something on the SD card. When I do that then Seq. show: HARD FAULT at PC=0x0002fca0 and seq. stop working. (sometimes computer too). I was try with different cards, but with same results. Is also the same if I start MSD from MIOS studio. Everything is normal when use card directly in PC, and then in Seq. I use PC with Windows XP. 2. I cant get sysex thru MBSeq. MIDI MONITOR is shown input (sysex) normally , but on out port is nothing. Is the same if I use USB or "normal" MIDI port. I was try with different router settings, but no results. Notes, CC ... working normally. Did I miss something or this is normal? Thanks in advance and Best Regards, IGI
TK. Posted December 28, 2011 Report Posted December 28, 2011 Hi, 1. When I enabled MSD USB everything is OK, until I try change something on the SD card. When I do that then Seq. show: HARD FAULT at PC=0x0002fca0 and seq. stop working. (sometimes computer too). I was try with different cards, but with same results. Is also the same if I start MSD from MIOS studio. Everything is normal when use card directly in PC, and then in Seq. I use PC with Windows XP. Before I build up my old PC equipment in the cellar I would like to know, if this happens with the STM32 or LPC17 based core. 2. I cant get sysex thru MBSeq. MIDI MONITOR is shown input (sysex) normally , but on out port is nothing. Is the same if I use USB or "normal" MIDI port. I was try with different router settings, but no results. Notes, CC ... working normally. Did I miss something or this is normal? Of course, this isn't normal. I checked this and found the reason (happens since a change in MIOS32 MIDI event handling) SysEx forwarding will work properly again with the next version! :) Best Regards, Thorsten.
igi Posted December 28, 2011 Author Report Posted December 28, 2011 HI! 1. Outside from the question frame: "I have two questions about SeqV4.054 (LPC core)." YES I use LPC17core! :thumbsup: 2. OUf'''' I will be happier if I could do that ! Man!..............Thanks! and Best Regards!
