SeqV4 card access +
igi
Hi!
I have two questions about SeqV4.054 (LPC core).
1. When I enabled MSD USB everything is OK, until I try change something
on the SD card.
When I do that then Seq. show: HARD FAULT at PC=0x0002fca0 and
seq. stop working. (sometimes computer too). I was try with different cards, but with
same results.
Is also the same if I start MSD from MIOS studio.
Everything is normal when use card directly in PC, and then in Seq.
I use PC with Windows XP.
2. I cant get sysex thru MBSeq.
MIDI MONITOR is shown input (sysex) normally , but on out port
is nothing. Is the same if I use USB or "normal" MIDI port.
I was try with different router settings, but no results.
Notes, CC ... working normally.
Did I miss something or this is normal?
Thanks in advance and Best Regards, IGI
on the SD card.
same results.
Before I build up my old PC equipment in the cellar I would like to know, if this happens with the STM32 or LPC17 based core.
Of course, this isn't normal.
I checked this and found the reason (happens since a change in MIOS32 MIDI event handling)
SysEx forwarding will work properly again with the next version! :)
