I still got the decribed behaviour.
- I used external power (18V) for JDM.
Ok, programming seems to work without problems.
Even progrmming a 00-Buffer works now.
- I sacrificed the first PIC and soldered another one to explude that this PIC was really detroyed.
(BTW: I noticed that this new PIC could not be programmed without external power for the JDM, the older one could, but with errors, and reading problems - never the same reading result)
- I burned the bootloader (ok)
- I uploaded MIOS via sysex (ok, no error string)
But MIOS will not run correctly. I get the request from the prim bootloader again and again. After each 2s.
So I can imagine that there are only some possibilities:
1.)  MIOS is not uploaded correctly (not very likely)
2.)  MIOS crashes (my guess)
3.)  MIOS has a bug (not very likely)
Any Ideas?
That would be true if nothing will ne loaded.
But the bootloader sends correct acknowledge-messages with the rigth check sum.
And if I read the PIC out than there was something loaded into the flash.
I only have to check if this procedure works 100% correctly. Not today, perhaps this evening.
