Hi everybody,
i have some question about controlling these
"current instrument" parametes via NRPN:
How do i change which is the "current" one in different engines?
According to the manual:
"...the final destination depends on the selection on the control
surface, or on the MIDI channel..."
I tried different midi channels and also
all edit screens, but its allways controlling instrument 1
Thanks for help
Marxon
Hi Marxon,
according to the way how you are asking I assume that you noticed that the current instrument selection isn't working in Multi mode?
I looked into the source code - according to the comments I planned to add a special handling for Multi mode, but the code is missing (instead the L/R selection will be taken, but this makes only sense for Lead/Bassline/Drum engine).
Or did you notice something else?
The MIDI channel will only be considered during the SID selection.
Hi TK,
thanks for your reply!
Ok i really have not described my problem very well. But i´ve forgotten your comments about multimode, too ;)
I like to control the drum engine instruments.
So i mapped the "current parameters" NRPN 32 - 40 on my midi controller but dont know
how to select different instruments.
Marxon
I will fix this soon, because I would like to control the parameters from a controller (Lemur on iPad) as well! :)
  • 3 months later...
Hi again TK,
did you made some progress with the current instrument selection?
I know you work very much, so dont feel stressed :)
Best regards
Marxon
  • 7 months later...
Hi again TK,
i dont want to get on your nerves :angel: but
is this "current instrument" thing still on your todo list?
Best regards
Marxon
I'm currently not so much into assembly programming... but thanks for the reminder - at least before new year I will clean up the open topics ;)
Two good news at once :thumbsup:
I also cant await the release of Midibox NG :frantics:
Best regards
Marxon
  • 2 months later...
Hallo wiedermals,
gleiches Anliegen anderer Lösungsansatz:
könnte man nicht einfach im Sequenzer (Midirouter) eine spezielle SidDrum Destination erstellen,
die alle empfangenen current Instrument Parameter der Drum Engine (Attack, Decay...)
zum aktiven, im Sequenzner ausgewählten Drum Instrument "umroutet"?
Aber ich vermute, dass ich mir das zu einfach vorstelle...
mfg
Marxon
The NRPN issue is finally fixed in v2.043
For drums I've currently no solution - it needs some time to work this out so that it works properly for all usecases (not only your own usecase that you mentioned...)
  • 11 months later...
Hi TK,
you implemented a lot new CCs for the Bassline, Drum and Multi Engine.
Did you also find a solution for the current instrument thing?
Best regards
Marxon
Hi Thorsten!
no, but I take this as a reminder...
 ...the fourth one :wink:
But it´s Ok!
You work very much on your awesome MIDIbox project anyway!
Best regards
Marxon
  • 2 months later...
It's still on my TODO list, but with low prio because you are the only guy who requested this yet
I just remember that I have (due your tip with the MidiRex) a unused LPC core.
Maybe i build a small MidiboxNG with:
-1 encoder to select the current instrument
-8 Encoders for the drum parameters
-some buttons to select the drum model
Or even better would be to use the Sid encoders itself.
I imagine something like this
post-4098-0-48924000-1403906672_thumb.jp
What do you think about it?
Best regards
Marxon
EDIT:
Maybe it´s better to move this post to the MidiboxNG section.
Edited by Marxon
Of course, this should be possible.
Alternatively you could control the parameters via SysEx, so that there is no MIDI channel dependency.
Ok, thank you Thorsten!
And what´s about the SID control surface encoders itself?
I can´t find any Sysex or NRPN which "simulate" them.
Englisch kann ich das evtl nicht genau erklären... Was ich meine ist, dass
ich anstatt die NG mit eigenen Encodern auszustatten,
gerne die Sid eigenen 10 Control Surface Encoder (die 4 LFO/Filter Encoder jetzt mal nicht mitgezählt :smile:) nutzen möchte
und die NG quasi einfach davor zuschalten.
Die verschiedenen Funktionen/Parameter der Encoder lassen sich zwar per Sysex/NRPN steuern,
die Encoder selbst (sodass sich ihrer Funktion je nach Menü ändert) aber scheinbar nicht.
Gibt es da eine Lösung? Vielen Dank für deine Hilfe!
Best regards
Mfg
Marxon
This sounds like you are complaining me that encoders can't be "simulated" via SysEx or NRPN... :-/
It shouldn't be so difficult to add a pragmatic solution as long as it doesn't need to be documented, because I guess that you are they only guy who is interested on such a remote control...
Note that feedback won't be possible (too difficult to implement) - means: you won't be able to send the current values to MBNG, e.g. for LCD display or LED ring updates.
No, of course not! That was just an observation.
Which might could have been wrong.
So i stated "i can´t find any Sysex or NRPN..." and not "there is no Sysex or NRPN..."
:angel: :angel: :angel:
Sorry that I'm the only one . :sweat:
No documentation needed. I promise!
Good to know but so far I haven't even thought of.
Thanks for your response and have a nice weekend!
Best rgards
Marxon
this subject interests me as well.
While i am still buissy building my hardware and am using a cs prototype untill now, the remote options via sysex are an interesting alternative for those who wish to adapt the synth-engine to personal workflow.
I am pretty sure i will stick to the options the SID application provides, but i also see MB_NG as really powerful alternative.
Optical feedback, other LCD options would be phantastic in terms of "bling".
After all the reading i did, i am wondering if it might be straight forward to have the MB_NG handle the CS encoders AND patch management - so that parameter values are available for display.
As, i said, i am happy with the synth, very happy so i´ll just build it. But still, MB_NG seems so powerful this topic sounds very interesting. Sid with LED rings....
