AoutLC and filter (SOLVED!)
Posted (edited)
Hi!
I noticed one problem with controlling external filter.
I use MBsid V2 (rc38) with AoutLC (cutoff 12bits,resonance 4 bits).
Everything if working just fine, but:
For example:
(all modulations (LFO's, EG's) is turned off)
cutoff value is 0, and I hold any key pressed then cca.every 5 seconds voltage is increase for 1,25V.
(I use 0 to 5V)
When key is pressed value=0V, after 5sec. value=1,25V ,after 10sec. value=3V ... until voltage is 5V.
If I release key and press it again voltage stays on last value.
On display value is still 000.
I can set voltage to 0V again only if I move cutoff knob.
Resonance voltage is working normally.
Any ideas???
Thanks in advance and best regards,IGI
I just noticed that problem is not in Aout, because there is the same problem
with internal (SID's) filter.
SOLVED!!!!
I upload application again and.....that is this :frantics: !
Edited by igi
Posted (edited)
HI!
TK, thanks for your reply.
I check my computer, but I did not find any viruses, so I hope you are wrong. :cry:
Problem is that you are usually right!!!
I also check my room and I found mostly MIDIBOX gear and no virus! :thumbsup:
I will report If I have more problems.
Best regards, IGI
Edited by igi
