igi Posted February 4, 2012 Report Share Posted February 4, 2012 (edited) Hi! I noticed one problem with controlling external filter. I use MBsid V2 (rc38) with AoutLC (cutoff 12bits,resonance 4 bits). Everything if working just fine, but: For example: (all modulations (LFO's, EG's) is turned off) cutoff value is 0, and I hold any key pressed then cca.every 5 seconds voltage is increase for 1,25V. (I use 0 to 5V) When key is pressed value=0V, after 5sec. value=1,25V ,after 10sec. value=3V ... until voltage is 5V. If I release key and press it again voltage stays on last value. On display value is still 000. I can set voltage to 0V again only if I move cutoff knob. Resonance voltage is working normally. Any ideas??? Thanks in advance and best regards,IGI I just noticed that problem is not in Aout, because there is the same problem with internal (SID's) filter. SOLVED!!!! I upload application again and.....that is this :frantics: ! Edited February 4, 2012 by igi Quote Link to comment Share on other sites More sharing options...
TK. Posted February 5, 2012 Report Share Posted February 5, 2012 Woah! Sounds like the installation was infected by a virus! ;) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
igi Posted February 6, 2012 Author Report Share Posted February 6, 2012 (edited) HI! TK, thanks for your reply. I check my computer, but I did not find any viruses, so I hope you are wrong. :cry: Problem is that you are usually right!!! I also check my room and I found mostly MIDIBOX gear and no virus! :thumbsup: I will report If I have more problems. Best regards, IGI Edited February 6, 2012 by igi Quote Link to comment Share on other sites More sharing options...
