CSC Posted April 28, 2012 Posted April 28, 2012 I need a new program for my Midi Project CSC.... a preprogrammed sample is already in the repository in the apps/quickies/csc folder. The Based Version was created with 40 Enocders, 128 Pots, an 2 16x16 Matrices at 4x AINX4 Modules, 4x DINX4 Modules, 1x DOUTX4 Module at a Core32 Board over USB to the XP PC. The new Version has 4 Encoders more. I have also tried to change the details in the program, but it doesn´t work. Can someone write a new program or an update for this Controller? It worked fine with 40 Enoder and all other parts till i build in the 4 Encoders in. Thanks a lot for help. Greets Chris
CSC Posted May 15, 2012 Author Posted May 15, 2012 Can someone help ?? The Program already exists in the Repository of Mios32/trunk/apps/quickies/csc , but it has to be updated... Greets CSC
philetaylor Posted May 15, 2012 Posted May 15, 2012 (edited) Hi. What have you tried so far? I am assuming that you have put the next 4 encoders on SR 11? If not then the code needs quite a bit more changing, I would recommend putting them on SR11 and moving the matrices over to SR12-SR15 If you have put the encoders on SR11, the code changes that you will need are: in app.c, change #define NUM_ENCODERS 40 to #define NUM_ENCODERS 44 in mios32_config.h change: #define FIRST_ENC_DIN_SR 1 #define DIN_16x16_L0 11 #define DIN_16x16_R0 12 #define DIN_16x16_L1 13 #define DIN_16x16_R1 14 to: #define FIRST_ENC_DIN_SR 1 #define DIN_16x16_L0 12 #define DIN_16x16_R0 13 #define DIN_16x16_L1 14 #define DIN_16x16_R1 15 I can't see any other changes that will be required but I may be wrong :) EDIT: Having looked at DINs.png, I can see that you have put the matrices on the first DINs and the encoders after them? That is the opposite of the way that the program is written and I would definitely recommend that you reconfigure it so that the encoders are on SR1-11 and the matrices are on SR12-15 otherwise the changes to the program are non-trivial (although still not that complicated!) Phil Edited May 15, 2012 by philetaylor
CSC Posted May 18, 2012 Author Posted May 18, 2012 i become a f... o.. with this. :sick: Now i build in, 4 Encoder more. So, i have the Shift Register 1-12 (DINX4_1 - DINX4_3) complete connected with Encoder. I changed any point in the Program... #define NUM_ENCODERS 48 #define NUM_MATRICES 2 #define FIRST_ENC_DIN_SR 1 // DINs of first 16x16 matrix (counted from 1) #define DIN_16x16_L0 13 #define DIN_16x16_R0 14 // DINs of second 16x16 matrix (counted from 1) #define DIN_16x16_L1 15 #define DIN_16x16_R1 16 // DOUTs of both matrices #define DOUT_16x16_L 1 #define DOUT_16x16_R 2 Now the new last 4 Encoders doesn´t work but the 4 Encoder that i connected before... :question: What a hell!? and Now the Matrices doesn´t work well. i don´t give up!! :hairy: I will try to change the parameters of the matrices and take look a the encoder connections, and send after a new try some feedback.....
CSC Posted May 25, 2012 Author Posted May 25, 2012 (edited) Error Update!!! --------------- I don´t need new Program... one little complication is still working. One Button in the Matrix makes a double note, and the last open Shift Register (Shift Register 11) is not reading. I have 48 (44) Encoder at Shift Regitser 1-11 and the Button Matrices at 13-16... I replaced the 4 new Encoders at SR11 with 8 Buttons, but it doesn´t work... finish UPDATE......! ALL BUTTONS and ALL FADERS, POTIS are alright. the last and the least 4 Encoders doesn´t want work. I replaced the 4 encoders with 8 Buttons and filled in, the code, into the program. but it doesn´t work... the 4 encoders, that i have planned before, are working fine.. In the program are 48 Encoders placed, but 44 Encoders are working... What´s the Problem ??? thanks...and greets... Edited June 2, 2012 by CSC
