I need a new program for my Midi Project CSC....
a preprogrammed sample is already in the repository in the apps/quickies/csc folder.
The Based Version was created with 40 Enocders, 128 Pots, an 2 16x16 Matrices at 4x AINX4 Modules, 4x DINX4 Modules, 1x DOUTX4 Module at a Core32 Board over USB to the XP PC.
The new Version has 4 Encoders more.
I have also tried to change the details in the program, but it doesn´t work.
Can someone write a new program or an update for this Controller?
It worked fine with 40 Enoder and all other parts till i build in the 4 Encoders in.
Thanks a lot for help.
Greets Chris
post-8517-0-14111600-1335636411_thumb.pn
post-8517-0-84848400-1335636433_thumb.jp
post-8517-0-50283300-1335636453_thumb.jp
  • 3 weeks later...
Can someone help ??
The Program already exists in the Repository of Mios32/trunk/apps/quickies/csc , but it has to be updated...
Greets CSC
Hi.
What have you tried so far? I am assuming that you have put the next 4 encoders on SR 11? If not then the code needs quite a bit more changing, I would recommend putting them on SR11 and moving the matrices over to SR12-SR15
If you have put the encoders on SR11, the code changes that you will need are:
in app.c, change
#define NUM_ENCODERS 40
to
#define NUM_ENCODERS 44
in mios32_config.h change:
#define FIRST_ENC_DIN_SR 1
#define DIN_16x16_L0 11
#define DIN_16x16_R0 12
#define DIN_16x16_L1 13
#define DIN_16x16_R1 14
to:
#define DIN_16x16_L0 12
#define DIN_16x16_R0 13
#define DIN_16x16_L1 14
#define DIN_16x16_R1 15
I can't see any other changes that will be required but I may be wrong :)
EDIT: Having looked at DINs.png, I can see that you have put the matrices on the first DINs and the encoders after them? That is the opposite of the way that the program is written and I would definitely recommend that you reconfigure it so that the encoders are on SR1-11 and the matrices are on SR12-15 otherwise the changes to the program are non-trivial (although still not that complicated!)
Phil
Edited by philetaylor
i become a f... o.. with this. :sick:
Now i build in, 4 Encoder more. So, i have the Shift Register 1-12 (DINX4_1 - DINX4_3) complete connected with Encoder.
I changed any point in the Program...
#define NUM_ENCODERS 48
#define NUM_MATRICES 2
// DINs of first 16x16 matrix (counted from 1)
#define DIN_16x16_L0 13
#define DIN_16x16_R0 14
// DINs of second 16x16 matrix (counted from 1)
#define DIN_16x16_L1 15
#define DIN_16x16_R1 16
// DOUTs of both matrices
#define DOUT_16x16_L 1
#define DOUT_16x16_R 2
Now the new last 4 Encoders doesn´t work but the 4 Encoder that i connected before... :question:
What a hell!?
and Now the Matrices doesn´t work well.
i don´t give up!! :hairy:
I will try to change the parameters of the matrices and take look a the encoder connections, and send after a new try some feedback.....
Error Update!!!
I don´t need new Program...
one little complication is still working.
One Button in the Matrix makes a double note, and the last open Shift Register (Shift Register 11) is not reading.
I have 48 (44) Encoder at Shift Regitser 1-11 and the Button Matrices at 13-16...
I replaced the 4 new Encoders at SR11 with 8 Buttons, but it doesn´t work...
finish UPDATE......!
ALL BUTTONS and ALL FADERS, POTIS are alright.
the last and the least 4 Encoders doesn´t want work.
I replaced the 4 encoders with 8 Buttons and filled in, the code, into the program.
the 4 encoders, that i have planned before, are working fine..
In the program are 48 Encoders placed, but 44 Encoders are working...
What´s the Problem ???
thanks...and greets...
Edited by CSC
