"Each core module needs a unique MIOS device ID in the network. This ID is burned into the "PIC ID header" together with the Bootloader. The master should get the ID 00, the slaves ID 01, 02 and 03"
I'm going to build a MIDIbox SID V2. I want to buy Programmed PIC18F4685. Do i need all the four PIC18F4685s to be programmed? or only the master should be programmed (ID00)?
Thank you, Roy.
Yes!
all the four PIC18F4685s to be programmed with the IDs: 00, 01, 02, 03. An every engine has a unique ID.
In the many Gallery pic's you can see that, too.
Regards,
Janis
Yes!
Regards,
Janis
THanks!~
