rogic Posted October 22, 2002 Posted October 22, 2002 Hello,is it possible to have more than 40 buttons in MIDIBOX64? I read on DIN module page that 4 ICs can give only 32 digital inputs and firmware of MIDIbox 64 gives maximum 40 inputs (with 5 ICs)...? We need something like a 'special case' midibox - 32 knobs and more than 32 buttons. Can somebody help?thanx
lemonhorse Posted October 22, 2002 Posted October 22, 2002 hi Rogic,there is a way to have more then 32 buttons - just connect buttons instead of pots to the AIN module - there is a description how it works in this Forum: Topic: "AIN: potmeter/button" Â from Captain Hastings.:)remark:some special functions (MB64: META Events, Shortcuts...) are only implemented to the "real" (DIN-Modul) buttons... - lemonhorse
rogic Posted October 22, 2002 Author Posted October 22, 2002 hi Rogic,there is a way to have more then 32 buttons - just connect buttons instead of pots to the AIN module - there is a description how it works in this Forum: Topic: "AIN: potmeter/button" Â from Captain Hastings.:)remark:some special functions (MB64: META Events, Shortcuts...) are only implemented to the "real" (DIN-Modul) buttons... - lemonhorseAha, ok - thanks. I am not sure about that how many EXACTLY pots we need, but I'm sure we'll use this modification. Can you tell me exactly what are these special functions? We want to build Midibox64 to control Native Instruments Traktor... any special things about buttons for traktor?
lemonhorse Posted October 22, 2002 Posted October 22, 2002 If you assign META Events to the buttons - you're able to use special internal MB64 functions. This table contains all available Special Functions and parameters: http://www.ucapps.de/midibox/midibox64_sfb_table.txt Another usefull MidiBox button feature is the "Toggle Mode": when a button is configured for toggle mode and you press the button once there will be a "Note on (for example)" midi-message - and if you press the button the second time = there will be a "Note off" midi-message - so the button act like a "toggle switch". It's funnny somehow - but you can "emulate" the DIN "toggle mode button" by using a toggle switch in conjunction with the AIN modul - so (in my view) there is no problem in the end ;D Traktor:...unfortunately I'm not a Traktor user (jet).So you must take over Thorsten...  ;) Â
rogic Posted October 22, 2002 Author Posted October 22, 2002 Sorry to be boring, but I am a total newbie :-/>Another usefull MidiBox button feature is the "Toggle >Mode": when a button is configured for toggle mode >This table contains all available Special Functions and parameters: http://www.ucapps.de/midibox/midibox64_sfb_table.txtOk, I got it. It might be useful.But is this modification for analog input module -> buttons still limiting MIDIbox64 to 40 buttons? Can I have 40 buttons via DIN and additional 10 through AIN?
lemonhorse Posted October 22, 2002 Posted October 22, 2002 hi again (you're not boring :)) !..."the MIDIbox64 allows to connect up to 40 buttons = 5 ICs = 1 DINX3 and 1 DINX2" (T. Klose) http://www.ucapps.de/mbhp_din.htmlBut there are 4 predefined MB64 buttons:  - Snapshot (Special Function Button) - Exec (execution) - Right (navigation)- Left (navigation)In that case you have 36 free assignable buttons (+4 predefined buttons) provided by the DIN modules (hope my thoughts are correct - i only realised a MB64 with just 32 buttons...)...furthermore you have 64 potential "AIN-buttons" through 2x AINx4 http://www.ucapps.de/mbhp/mbhp_ainx4_64pots.pdf addendum:"The MIDIO128 interface enables you to drive up to 128 digital output pins and to react on up to 128 digital input pins via MIDI" (connection for a lot of buttons...;)) - perhaps it's a solution for your needs to combine the MB64 with the MIDIIO128...http://www.ucapps.de/midio128.htmlbest regards,- lemonhorse  Â
rogic Posted October 23, 2002 Author Posted October 23, 2002 >In that case you have 36 free assignable buttons (+4 >predefined buttons) provided by the DIN modules (hope >my thoughts are correct - i only realised a MB64 with just >32 buttons...)But you REALISED it! ;) I am still far away from that point... :-/>...furthermore you have 64 potential "AIN-buttons" through 2x AINx4>http://www.ucapps.de/mbhp/mbhp_ainx4_64pots.pdfOk, if we get this right, means that MIDIBox 64 can work with 40+ buttons, but through additional AIN modules... I hope it works like this.Thanks for answers lemonhead, I really need any help I can get
