scrubber Posted November 16, 2012 Posted November 16, 2012 Hey yo yo! sickening times with the sammichSID! love it! I'm working on making a patch to send the various CC info to the different voices/parts and noticed that only the lead engine has the CC messages implemented Have the other channles/voices been set up yet or is this somethign that needs to be done? if it needs to be done, where would someone begin to work on the other engines? any advice would be top! cheers!this chart: http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fdoc%2Fmbsidv2_cc_chart.txt
TK. Posted November 16, 2012 Posted November 16, 2012 Hi, some time ago I asked for a reasonable reduced set of parameters which should be directly controlled via CCs, but I haven't got any response - therefore this feature is still only available for the lead engine as some kind of demonstrator. However, probably users (including myself) are already happy enough with the 8 knob functions, which can be controlled with CC#1, CC#16..19, Velocity, Aftertouch and Pitchbender. The big advantage of knob assignments is: a min/max range can be defined - it's even possible to switch the "polarity", and to assign two parameters to the same knob. Means in other words: depending on the patch you could configure knobs so that they lead to the most interesting sound changes within a given value range. Knob functions are documented here: http://www.ucapps.de/midibox_sid_manual_l.html (search for "knobs menu") And assignable parameters are available for all engines: http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fdoc%2Fmbsidv2_parameter_chart.txt Best Regards, Thorsten.
scrubber Posted November 17, 2012 Author Posted November 17, 2012 wicked mate! thanks for the info! Im on the case now! liking the idea of controlling several functions at once with one pot! making a patch for my Jazzmutant Lemur to work with the sammichSID as we speak! thanks for the links, these are no end of help!
