gtxdude Posted November 19, 2012 Posted November 19, 2012 I'm connecting an IIC rev2 to a STM32 core running SEQ4. The BLM connection is shown here: http://www.ucapps.de/midibox_blm/blm_connector_mbseq.pdf Where does MI2 and MO2 connect to on the core? I spent some time plumbing the depths of uCApps and the above drawing was as close as I could find. Any help would be much appreciated. Thanks, Gtx
daemonik Posted November 20, 2012 Posted November 20, 2012 It's spare! like noted in the document you reffering to! so... no need to connect it anywhere :thumbsup: If you'r using the Quad IIC Midi Modul from smashTV then also check this Schematic: http://www.midibox-shop.com/images/quad_IIcMIDI_schem.pdf cheers, Nick Ahhhhhhhhh... stupid me!!!! I've installed a 7pin instead of 8pin!!! argghhhhhh!!!!!
