tupinamba Posted January 13, 2013 Posted January 13, 2013 Hi everyone, Is there a way to copy / paste whole songs the same way a pattern can be copied / pasted ? The idea is to reorganize the Songs order to match changes in a setlist... Thanks!
TK. Posted January 13, 2013 Posted January 13, 2013 Yes, there is a simple and secure way: - create a "dummy" session (or just copy your current session into a new one with the "Save as..." function), and change to this dummy session - enter the Disk page (Utility->Disk) - select "Session Export" - at the left side, select the name of your original session - at the right side of the export page, select "Type: Songs", the source song number and the destination song number - enter EXPORT -> done If you make an error, you will have a full backup with your dummy session. It could be deleted later once you are sure that all songs have been transferred correctly. Best Regards, Thorsten.
tupinamba Posted January 13, 2013 Author Posted January 13, 2013 That is great. Thanks once again Thorsten! All the best, Gaël
