I'm using Wilbas control surface on my SEQV4.
I'm having trouble understanding what to do in phrase mode.
From the manual: "select the "Position" item by pushing Layer button B"
which button is this?
It's actually "Parameter Layer button B" (below the track selection buttons)
Background: the original frontpanel has no group or trigger layer selection buttons - therefore it was just button B
I added this detail to the manual.
Thanks TK, it seems to be working.
I'm still a bit unclear: the Phrase Mode GP buttons only access song positions A1,B1,C1,etc, and yet song positions include A2,A3,A4,etc
If a song position say A3 undefined and have a pattern action defined B1, then in song mode the song stays on A2 never progressing further.
So you can't use phrase mode to manually step through the parts of a song?
No, Phrase mode only executes A1/B1/C1/D1/E1/F1/G1/H1..8 until all positions have been executed which are not "time consuming".
E.g., the first step could contain a tempo change, the second step could fire a mixer map, and the third step could finally change the pattern set.
That's the intended usecase.
Yes...
BUT: in song mode, you can switch between A1/B1/C1/D1/E1/F1/G1/H1 as well with the same approach - in this case, the song should directly jump to the selected position, and it should continue to play.
