Duggle Posted January 15, 2013 Report Posted January 15, 2013 I'm using Wilbas control surface on my SEQV4. I'm having trouble understanding what to do in phrase mode. From the manual: "select the "Position" item by pushing Layer button B" which button is this? Quote
TK. Posted January 15, 2013 Report Posted January 15, 2013 It's actually "Parameter Layer button B" (below the track selection buttons) Background: the original frontpanel has no group or trigger layer selection buttons - therefore it was just button B I added this detail to the manual. Best Regards, Thorsten. Quote
Duggle Posted January 15, 2013 Author Report Posted January 15, 2013 Thanks TK, it seems to be working. I'm still a bit unclear: the Phrase Mode GP buttons only access song positions A1,B1,C1,etc, and yet song positions include A2,A3,A4,etc If a song position say A3 undefined and have a pattern action defined B1, then in song mode the song stays on A2 never progressing further. So you can't use phrase mode to manually step through the parts of a song? Quote
TK. Posted January 15, 2013 Report Posted January 15, 2013 No, Phrase mode only executes A1/B1/C1/D1/E1/F1/G1/H1..8 until all positions have been executed which are not "time consuming". E.g., the first step could contain a tempo change, the second step could fire a mixer map, and the third step could finally change the pattern set. That's the intended usecase. Best Regards, Thorsten. Quote
Duggle Posted January 15, 2013 Author Report Posted January 15, 2013 OK, so the intended usage is to set up a different song # for usage in song mode OR phrase mode, but not both, right? Quote
TK. Posted January 15, 2013 Report Posted January 15, 2013 Yes... BUT: in song mode, you can switch between A1/B1/C1/D1/E1/F1/G1/H1 as well with the same approach - in this case, the song should directly jump to the selected position, and it should continue to play. Best Regards, Thorsten. Quote
