dinama Posted March 18, 2013 Report Share Posted March 18, 2013 Hi.I have not programming skill so is about a week that i try to solve this thing.I want a special button for my midibox.This button have the same function of "snapshot at poweron" but manually triggered .So when i push this button the box will send all current pot settings ( actual values ​​marked by the position of the potentiometer not the one stored in bank) whithout store it in bank.In other words get the current physical position of all pots, and then transmit them to output midi port.I try to write a meta event to do thisMB64_META_Handlermovf MIDI_EVNT1, Wgoto MB64_PATCH_SendCurrentbut there is somethig wrong in this.I search on forums and i found a similar tread with a solution()unsigned char i;unsigned char MyArray[num_ains];for (i = 0 ; i <= num_ains ; i++) {MyArray[(i)] = MIOS_AIN_Pin7bitGet(i);}but this is a pseudocode and i don't have skill to translate it in a real solution.I think there is a simple solution with meta handler and existing functions but i don't see it.please can someone help me.thanks Quote Link to comment Share on other sites More sharing options...
TK. Posted March 18, 2013 Report Share Posted March 18, 2013 Just call MB64_PATCH_SendCurrent what's wrong with this function? Or do you want to send the current patch? Then call MB64_PATCH_Send The code is located in mb64_patch.inc (for your inspiration) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted March 19, 2013 Author Report Share Posted March 19, 2013 Hi. I try your solution but it does not work. i modify mb64_meta.inc MB64_META_Handler movf MIDI_EVNT1, W call MB64_PATCH_SendCurrent and compile a new hex file. This is the part of .ini file where the meta event is assigned to button [bUTTONS] # Additional 4 Buttons in the menu section 19 = F0 00 7f @Onoff these are other options active [sNAPSHOT_AT_POWERON] enabled [AUTO_SNAPSHOT] enabled When i turn on midibox i can see on display "Loading Setup from bankstick" then "Sending Snapshot" . After this the midibox turn-off alone, restart , again on display "Loading Setup from bankstick" and "Sending Snapshot" , then the box crash . the display text remains "Sending Snapshot". I try with goto MB64_PATCH_SendCurrent with same result. It like there is a loop that sends the machine in crash. i don't know When i delete movf MIDI_EVNT1, W call MB64_PATCH_SendCurrent the midibox return ok. Quote Link to comment Share on other sites More sharing options...
TK. Posted March 19, 2013 Report Share Posted March 19, 2013 Alright, now it's clear (you should have mentioned this earlier): since the MB64_PATCH functions also send the meta event, you will get an infinite loop. I remember that I had the same problem with the snapshot SFB, and I remember that I solved this by implementing a request flag mechanism in main.inc to ensure, that the patch is only sent once. So, new approach: write MB64_META_Handler bsf MB_STAT2, MB_STAT2_PWR_SNAPSHOT_REQ return if you want to request the MB64_PATCH_SendCurrent call or write MB64_META_Handler bsf MB_STAT, MB_STAT_SNAPSHOT_REQ return if you want to request the MB64_PATCH_Send call The USER_Tick function in main.inc will check this flag, call the appr. function if it's 1, and clear the flag thereafter. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted March 24, 2013 Author Report Share Posted March 24, 2013 perfect!!! thanks Quote Link to comment Share on other sites More sharing options...
dinama Posted March 24, 2013 Author Report Share Posted March 24, 2013 Sorry but after a few attempts i discovered a problem. i use your solution and i assign to a button the meta handler. MB64_META_Handler bsf MB_STAT2, MB_STAT2_PWR_SNAPSHOT_REQ return but now with [AUTO_SNAPSHOT] enabled when i change bank with button 17-18-19 midibox don't recall the values stored in bankstick but everytime make a snapshot of current pot position. if i use [AUTO_SNAPSHOT] disabled midibox recall the values stored in bankstick but don't sent it to midi out port. This is the part of .ini file where the meta event is assigned to button 17 = FF 04 00 @OnOnly 18 = FF 04 01 @OnOnly 19 = FF 04 03 @OnOnly 20 = F0 00 7F @OnOnly Quote Link to comment Share on other sites More sharing options...
TK. Posted March 24, 2013 Report Share Posted March 24, 2013 I've to ask you some questions to ensure that I understood you correctly: Which option do you want to use? [AUTO_SNAPSHOT] enabled? And you want that values are stored in BankStick, and that they are sent to the MIDI OUT? Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted March 24, 2013 Author Report Share Posted March 24, 2013 i think it's better for me to use [AUTO_SNAPSHOT] enabled because when in bank1 i push button 18 = FF 04 01 @OnOnly (or FF 02 01 if i don't want to save the value in bank1) i want to jump to bank 2 and restore value stored in bank2 and sent it to midi out. maybe the problem is the flag that i set in meta-handler for my special button MB64_META_Handler bsf MB_STAT2, MB_STAT2_PWR_SNAPSHOT_REQ return maybe USER_Tick function in main.inc don't clear the flag Quote Link to comment Share on other sites More sharing options...
TK. Posted March 24, 2013 Report Share Posted March 24, 2013 Could you please search in main.inc, if the flag is cleared? (this is a learning example which should help you to get a better understanding of the code without asking me ;-)) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted March 25, 2013 Author Report Share Posted March 25, 2013 Ok i think this is the line where the flag is reset in user tick bcf MB_STAT2, MB_STAT2_PWR_SNAPSHOT_REQ So why every time i change bank i don't have value stored in bank but the snapshot value? Quote Link to comment Share on other sites More sharing options...
TK. Posted March 26, 2013 Report Share Posted March 26, 2013 Yes, you are right. I'm surprised by myself that nobody noticed this yet! I can work on the MB64_PATCH_SendCurrent routine, so that the value is stored in the snapshot as well. But this needs some time... Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted April 3, 2013 Author Report Share Posted April 3, 2013 Any news? Quote Link to comment Share on other sites More sharing options...
TK. Posted April 3, 2013 Report Share Posted April 3, 2013 Not yet... as mentioned above, it will need some time. I've to open my MB64 case, replace the MBHP_CORE_LPC17 module by a MBHP_CORE, have to find out what I did years ago and then try out changes (which are error prone...) in order to help you on this topic. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted May 1, 2013 Author Report Share Posted May 1, 2013 news, please Quote Link to comment Share on other sites More sharing options...
TK. Posted May 2, 2013 Report Share Posted May 2, 2013 no news yet Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted May 29, 2013 Author Report Share Posted May 29, 2013 please give me a news. i'd like to finish my project. thanks Quote Link to comment Share on other sites More sharing options...
TK. Posted May 30, 2013 Report Share Posted May 30, 2013 currently too many people are giving me requests... Is this enhancement really so important? It seems that you are the only guy who is interested on this, or are there others (maybe even with programming skills) who could help out? Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
