Marxon Posted April 3, 2013 Posted April 3, 2013 Hi Midiboxers,i just wondering if it is possible to change the assignment of the OP 1-4 and Instr. 1-4 LEDs?Because there is no option in the cs_menu_io_tables...Or is it necessary to connect them like in the FM Dout schematic?Best regardsMarxon
TK. Posted April 3, 2013 Posted April 3, 2013 These LEDs are directly assigned to the first SR in cs_menu_matrix.inc The direct SR assignment (for all 8 pins) saves execution time and flash memory. As you already noticed, flash is very reduced for PIC18F452... and performance is an important topic as well. Best Regards, Thorsten.
Marxon Posted April 8, 2013 Author Posted April 8, 2013 The direct SR assignment (for all 8 pins) saves execution time and flash memory.As you already noticed, flash is very reduced for PIC18F452... and performance is an important topic as well.You are the master of 1´s and 0´s :smile:I am just a little solder guy.So i connect the LEDs like you think it is the best way to do.Oder auf deutsch: du wirst schon wissen was du tust :smile:Danke für die InfoGrußMarxon
