Duggle Posted April 4, 2013 Posted April 4, 2013 I'd like to use multiple CLCD's on a Core STM32 as part of an ongoing hardware debug excercise :happy: Of course the STM32 PCB does not have a J28 for the attachment of a DOUT board that provides the extra E lines to all the extra LCD modules. So my strategy for this was to implement the MIOS32_BOARD_J28_* routines (which at present for STM32, just return -1), with equivalent code that bitbangs J16 or J19. Is there an easy way to achieve this? I couldn't see support routines for J16 or J19 so I would I have to write these? Are there any major problems with what I'm proposing?
TK. Posted April 5, 2013 Posted April 5, 2013 J16 is used by the application to access the SD Card -> no way! J19 would be used by the application if the .NGC file enables the AINSER or CV port -> potential conflicts as well. Therefore I would propose to use J5C instead. In many applications (e.g. MBSEQ V4) J28 of the LPC17 core is used as a replacement for J5C of the STM32 core anyhow, so why not using it for your special case as well? Best Regards, Thorsten.
Duggle Posted April 5, 2013 Author Posted April 5, 2013 J16 is used by the application to access the SD Card -> no way! J19 would be used by the application if the .NGC file enables the AINSER or CV port -> potential conflicts as well. Therefore I would propose to use J5C instead. In many applications (e.g. MBSEQ V4) J28 of the LPC17 core is used as a replacement for J5C of the STM32 core anyhow, so why not using it for your special case as well? Thanks, TK. I'm glad I asked! J5 has support routines in mios32_board.c which will make it pretty straight forward to implement.
