Duggle Posted April 18, 2013 Posted April 18, 2013 Would it, could it, or will it ever be possible to include LABEL definitions in an NGC file? Its nice to be able to write the definition close to where it is being used.
TK. Posted April 18, 2013 Posted April 18, 2013 No, too difficult due to various reasons. Best Regards, Thorsten.
Duggle Posted April 18, 2013 Author Posted April 18, 2013 Fair enough. Anyway, it's not too difficult open an extra editor window. With the script/macro approach it's easy enough to split the LABEL lines to a separate file for output, anyhow.
TK. Posted April 18, 2013 Posted April 18, 2013 Related to this topic: Here a hint: with following perl script: while( <STDIN> ) { if( /^\s*#\s*NGL:\s*(.*)/ ) { print "$1\n"; } } you could simply *extract* NGL commands from a .NGC file. Example: # this is a .NGC file # we've some EVENT definitions here EVENT_xxx ... # and following commands should go into the .NGL file: # NGL: COND_LABEL octave # NGL: COND <28 "128'" # NGL: COND <40 " 64'" # NGL: COND <52 " 32'" # NGL: COND <64 " 16'" # NGL: COND <76 " 8'" # NGL: COND <88 " 4'" # NGL: COND <100 " 2'" # NGL: COND <112 " 1'" # NGL: COND <124 "1/2'" # NGL: COND_ELSE "???'" call: perl my_ngl_filter.pl < test.ngc > test.ngl and you are done! :smile: -> COND_LABEL octave COND <28 "128'" COND <40 " 64'" COND <52 " 32'" COND <64 " 16'" COND <76 " 8'" COND <88 " 4'" COND <100 " 2'" COND <112 " 1'" COND <124 "1/2'" COND_ELSE "???'" Best Regards, Thorsten.
Duggle Posted April 18, 2013 Author Posted April 18, 2013 Thanks for the hint, TK! (I'll continue discussion in the other thread)
