ibanman555 Posted May 17, 2013 Posted May 17, 2013 (edited) Hi Everyone, I am curious if using the MBNP_CORE_LPC17 and MBNG_AOUT_NG together and programmed properly with this meter (http://www.jlmaudio.com/shop/index.php?_a=viewProd&productId=100) would allow me to have 32 meters functional for my DAW controller? There are CV inputs for this meter, but it seems to be aimed towards 'gain reduction' as a function. Otherwise, how would you normally hook up this meter to a DAW controller? Such a noob over here, getting my bearings on what can actually be done. Thanks! Edited May 17, 2013 by ibanman555
TK. Posted May 18, 2013 Posted May 18, 2013 Somehow this doesn't make much sense. This meter is intended for audio signals, not for MIDI. I also don't see a way how you could access the audio channels of your DAW with such a meter. Best Regards, Thorsten.
ibanman555 Posted May 20, 2013 Author Posted May 20, 2013 Thanks, that's what i was thinking too. I only ask because I really like the meter itself and would like to use it on my build. I assume there is no way to integrate it for midi input...
