Duggle Posted June 10, 2013 Posted June 10, 2013 Would it be possible to implement line continuation character in NGR? I'm wanting to send a long Sysex message which I would like to type over multiple lines for clarity. Here's a shorter example: send SysEx OUT3 0xf0 0x00 0x01 0x00 0x01 0x00 0x7f 0x00 0x10 16 0xf7 but send SysEx OUT3 0xf0 0x00 0x01 0x00 \ 0x01 0x00 0x7f 0x00 \ 0x10 16 0xf7 doesn't work.
Duggle Posted June 10, 2013 Author Posted June 10, 2013 I worked around this by triggering a SENDER. EVENT_SENDER id=102 type=SysEx ports=1000001000000000 stream="0xf0 0x00 0x01 0x00 0x01 \ 0x00 0x00 0x00 0x00 10 \ 0x00 0x00 0x01 0x34 10 \ 0xf7" from the NGR: if ^section == 6 trigger SENDER:102 endif The problem is now that there is a strict limit on the length of the Sysex stream. It seems to fail to find the SENDER if the stream is a bit longer than the one shown above. Is there a way of sending larger Sysex messages?
TK. Posted June 16, 2013 Posted June 16, 2013 The problem is now that there is a strict limit on the length of the Sysex stream. It seems to fail to find the SENDER if the stream is a bit longer than the one shown above. I'm surprised! The maximum stream size is 128 bytes. Did you get an error message while loading the .NGC file? Or was this just an assumption, but the reason why longer SysEx streams can't be sent (or received at the destination?) is located somewhere else? Best Regards, Thorsten.
TK. Posted June 16, 2013 Posted June 16, 2013 Would it be possible to implement line continuation character in NGR? Working again in v1.026 Best Regards, Thorsten.
