mikee Posted July 2, 2013 Report Posted July 2, 2013 Hi all. Does anyone know how on earth one is supposed to turn the midi merger on? What buttons are used? Is button 4 both a snapshot and 'enter' button? As per title, if I manage to set the midi merger to on, is it meant to retain the new setting when powered down? thanks in advance for any advice. Regards to all
TK. Posted July 22, 2013 Report Posted July 22, 2013 Hi, see this tutorial: http://www.ucapps.de/midibox64_tutorial.html search for "merge" The change takes place immediately. The value is stored in the bank, which is either the internal EEPROM (if no BankStick connected), or the external EEPROM (the BankStick). It will be restored after power-on from the default bank, and on bank changes. Best Regards, Thorsten.
mikee Posted July 25, 2013 Author Report Posted July 25, 2013 Thanks for the info TK, it is appreciated. After construction I found that the merger is already on, so that was cool. The big problem seems to be that system FE commands (active sensing) prevent proper merger operation. I built your filter, modified it to ignore system commands, and all is well in the world. Thank you for all your hard work. regards.
