Posted (edited)
Hi, i solved this using the low-cost adapter like the ucapps site.
(Hi to everyone,
I got recently a midibox seq v4 lite from the fleamarket, so i did't build by myself, works, but not the sdcard.
I use a sdhc 4gb, partitioned to 900 MB with a FAT16, in the MIOS terminal give me this error:
[4384.701] [disk_initialize] error while checking for SD Card (status 0)
[4384.703] [FILE] Failed to open root directory - error status: 13
[4385.700] SD Card disconnected
There's a card pcb with the slot, not the low-cost solution, look at the connection seem all ok, the only thing is the ground that only one it's soldered.
I would try to make the low-cost adapter on the ucapps site, but if someone know how to check or maybe i wrong something...i would like to see if it's all ok before build the adaptor.
I'm new in electronics and in midibox but i'm able to solder some wire.
Thanks)
Edited by jagzik
