Is it possible? I had it figured out awhile ago so that I could record the CCs that my SIDv2 makes when I use the knobs, then loop it back into the SID along with the original notes, but since I've upgraded my setup I haven't been able to reproduce the same effect. I've tried going the midi-through route with looping the CCs into the original "commander" keyboard, but it doesn't have midi-thru :/ I'd do it with a computer but I'm trying to get away from using a DAW, any help is appreciated :D
-Ajax
