Hi Midiboxers!
Thorsten's Midibox NG can be a little beast in terms of complexity for me ;)
It would be great if someone can help me.
I like to equip my Midibox NG with 16 8-segment led bars.
Each bar should be controlled with a separate received CC event like this way:
CC value = 0 -> all bar segments off
CC value = 64 -> bar segment 1,2,3,4 on
CC value = 127 -> all bar segments on
Due to the conditions of my box, I decided to divide them into two 4x16 matrices (one column = 2x8-led bars)
Every matrix is driven by 3 DOUT-SRs.
Matrix 1
SR1 D7 - D0 are connected to the anodes of LED Bar 1, 3, 5, 7 (column 1-8)
SR2 D7 is connected to all cathodes of bar 1, 2 (row 1)
SR2 D6 is connected to all cathodes of bar 3, 4 (row 2)
SR2 D5 is connected to all cathodes of bar 5, 6 (row 3)
SR2 D4 is connected to all cathodes of bar 7, 8 (row 4)
SR3 D7 - D0 are connected to the anodes of LED Bar 2, 4, 6, 8 (column 9-16)
But now i am confused how to control the led bars independently via CCs because they are parts of led matrix columns.
Led matrix patterns?
Each led separately with emu_led_offset?
Range mapping?
Thanks for any suggestions!
Best regards
Marxon
Edited by Marxon
There is nothing more to say!
I mistakenly missed out the LED Digit topic and thought to have no usecase for it.
Thank you Thorsten.
Marxon
This was probably a little bit hasty...
The LED Digit example does not clarify the issue because
it is a pair of 8x8 matrices.
I have made a sketch to explain what my problem is.
post-4098-0-56820700-1385843172_thumb.jp
How can i control led bar 1 with a CC and
led bar 2 with another one although they are in the same column?
I tried to assign two diffewrent patterns but as expected they interrupt each other.
DOUT_MATRIX n=1   rows=4   sr_dout_r1=3  sr_dout_sel1=4  sr_dout_r2=5
DOUT_MATRIX n=2   rows=4   sr_dout_r1=6  sr_dout_sel1=7  sr_dout_r2=8
EVENT_LED_MATRIX id=1  led_matrix_pattern=1  fwd_to_lcd=1  type=CC chn= 1 cc= 1  lcd_pos=1:1:2  label="1:%3d%B"
EVENT_LED_MATRIX id=2  led_matrix_pattern=2  fwd_to_lcd=1  type=CC chn= 1 cc= 2  lcd_pos=1:1:2  label="1:%3d%B"
LED_MATRIX_PATTERN n= 1   pos= 0  pattern=0000000000000000
LED_MATRIX_PATTERN n= 1   pos= 1  pattern=1000000000000000
LED_MATRIX_PATTERN n= 1   pos= 2  pattern=1000000000000000
LED_MATRIX_PATTERN n= 1   pos= 3  pattern=1100000000000000
LED_MATRIX_PATTERN n= 1   pos= 4  pattern=1110000000000000
LED_MATRIX_PATTERN n= 1   pos= 5  pattern=1110000000000000
LED_MATRIX_PATTERN n= 1   pos= 6  pattern=1111000000000000
LED_MATRIX_PATTERN n= 1   pos= 7  pattern=1111000000000000
LED_MATRIX_PATTERN n= 1   pos= 8  pattern=1111100000000000
LED_MATRIX_PATTERN n= 1   pos= 9  pattern=1111100000000000
LED_MATRIX_PATTERN n= 1   pos=10  pattern=1111110000000000
LED_MATRIX_PATTERN n= 1   pos=11  pattern=1111110000000000
LED_MATRIX_PATTERN n= 1   pos=12  pattern=1111111000000000
LED_MATRIX_PATTERN n= 1   pos=13  pattern=1111111000000000
LED_MATRIX_PATTERN n= 1   pos=14  pattern=1111111100000000
LED_MATRIX_PATTERN n= 1   pos=15  pattern=1111111100000000
LED_MATRIX_PATTERN n= 2   pos= 0  pattern=0000000000000000
LED_MATRIX_PATTERN n= 2   pos= 1  pattern=0000000010000000
LED_MATRIX_PATTERN n= 2   pos= 2  pattern=0000000010000000
LED_MATRIX_PATTERN n= 2   pos= 3  pattern=0000000011000000
LED_MATRIX_PATTERN n= 2   pos= 4  pattern=0000000011100000
LED_MATRIX_PATTERN n= 2   pos= 5  pattern=0000000011100000
LED_MATRIX_PATTERN n= 2   pos= 6  pattern=0000000011110000
LED_MATRIX_PATTERN n= 2   pos= 7  pattern=0000000011110000
LED_MATRIX_PATTERN n= 2   pos= 8  pattern=0000000011111000
LED_MATRIX_PATTERN n= 2   pos= 9  pattern=0000000011111000
LED_MATRIX_PATTERN n= 2   pos=10  pattern=0000000011111100
LED_MATRIX_PATTERN n= 2   pos=11  pattern=0000000011111100
LED_MATRIX_PATTERN n= 2   pos=12  pattern=0000000011111110
LED_MATRIX_PATTERN n= 2   pos=13  pattern=0000000011111110
LED_MATRIX_PATTERN n= 2   pos=14  pattern=0000000011111111
LED_MATRIX_PATTERN n= 2   pos=15  pattern=0000000011111111
Edited by Marxon
Ah! Sorry, I picked up the wrong example.
This is a better one: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Ftpd.ngc
(it tests the TPD, which consists of two 8x8 duo-LED matrices, driven by DOUT_MATRIX n=2 and n=3)
As you can see, each DOUT_MATRIX has 16 EVENT_LED_MATRIX entries, regardless of the number of rows.
In order to ensure individual access, I would propose to define 4 DOUT_MATRIX items:
/edit: corrected DOUT_MATRIX assignments.
DOUT_MATRIX n=1   rows=4   sr_dout_sel1=4  sr_dout_r1=3
DOUT_MATRIX n=2   rows=4   sr_dout_sel1=4  sr_dout_r1=5
DOUT_MATRIX n=3   rows=4   sr_dout_sel1=7  sr_dout_r1=6
DOUT_MATRIX n=4   rows=4   sr_dout_sel1=7  sr_dout_r1=8
you should be able to control the LED bars with:
EVENT_LED_MATRIX id= 1 type=CC  chn= 1 cc= 16  led_matrix_pattern=1
EVENT_LED_MATRIX id= 2 type=CC  chn= 1 cc= 17  led_matrix_pattern=1
EVENT_LED_MATRIX id= 3 type=CC  chn= 1 cc= 18  led_matrix_pattern=1
EVENT_LED_MATRIX id= 4 type=CC  chn= 1 cc= 19  led_matrix_pattern=1
EVENT_LED_MATRIX id=17 type=CC  chn= 1 cc= 20  led_matrix_pattern=1
EVENT_LED_MATRIX id=18 type=CC  chn= 1 cc= 21  led_matrix_pattern=1
EVENT_LED_MATRIX id=19 type=CC  chn= 1 cc= 22  led_matrix_pattern=1
EVENT_LED_MATRIX id=20 type=CC  chn= 1 cc= 23  led_matrix_pattern=1
EVENT_LED_MATRIX id=33 type=CC  chn= 1 cc= 24  led_matrix_pattern=1
EVENT_LED_MATRIX id=34 type=CC  chn= 1 cc= 25  led_matrix_pattern=1
EVENT_LED_MATRIX id=35 type=CC  chn= 1 cc= 26  led_matrix_pattern=1
EVENT_LED_MATRIX id=36 type=CC  chn= 1 cc= 27  led_matrix_pattern=1
EVENT_LED_MATRIX id=49 type=CC  chn= 1 cc= 28  led_matrix_pattern=1
EVENT_LED_MATRIX id=50 type=CC  chn= 1 cc= 29  led_matrix_pattern=1
EVENT_LED_MATRIX id=51 type=CC  chn= 1 cc= 30  led_matrix_pattern=1
EVENT_LED_MATRIX id=52 type=CC  chn= 1 cc= 31  led_matrix_pattern=1
Hi Thorsten,
unfortunately your Code
DOUT_MATRIX n=1   rows=4   sr_dout_r1=3  sr_dout_r2=5
DOUT_MATRIX n=2   rows=4   sr_dout_r1=4  sr_dout_r2=5
DOUT_MATRIX n=1   rows=4   sr_dout_r1=6  sr_dout_r2=8
DOUT_MATRIX n=2   rows=4   sr_dout_r1=7  sr_dout_r2=8
does not work.
Would you please explain it to me?
1) Why are the sr_dout_sel missing or are they just declared as sr_dout_r2?
2) Do you mean EVENT_LED_MATRIX entry has a 16 step pattern?
3) Shouldn't be the code
like this (different matrix numbering)
DOUT_MATRIX n=3   rows=4   sr_dout_r1=6  sr_dout_r2=8
DOUT_MATRIX n=4   rows=4   sr_dout_r1=7  sr_dout_r2=8
Best regards
Marxon
Edited by Marxon
Sorry, my fault.
It should be:
Does this make more sense? ;)
no, I mean that
EVENT_LED_MATRIX id=1..16 are assigned to DOUT_MATRIX id=1
EVENT_LED_MATRIX id=17..32 are assigned to DOUT_MATRIX id=2
EVENT_LED_MATRIX id=33..48 are assigned to DOUT_MATRIX id=3
EVENT_LED_MATRIX id=49..64 are assigned to DOUT_MATRIX id=4
each id controls a column (LED bar)
You've only 4 LED bars per DOUT_MATRIX, accordingly only id=1..4, id=17..20, id=33=36, id=49..52 are relevant, the others can be ignored.
no, I mean that
Ah now i got it:
this why you count in your tpd.ngc example:
EVENT_LED_MATRIX id=22 type=CC  chn= 1 cc= 21  led_matrix_pattern=1  rgb=15:15:15
EVENT_LED_MATRIX id=23 type=CC  chn= 1 cc= 22  led_matrix_pattern=1  rgb=15:15:15
EVENT_LED_MATRIX id=24 type=CC  chn= 1 cc= 23  led_matrix_pattern=1  rgb=15:15:15
# CC 24..31
EVENT_LED_MATRIX id=33 type=CC  chn= 1 cc= 24  led_matrix_pattern=1  rgb=15:15:15
EVENT_LED_MATRIX id=34 type=CC  chn= 1 cc= 25  led_matrix_pattern=1  rgb=15:15:15
EVENT_LED_MATRIX id=35 type=CC  chn= 1 cc= 26  led_matrix_pattern=1  rgb=15:15:15
 and not
# CC 24..31
EVENT_LED_MATRIX id=25 type=CC  chn= 1 cc= 24  led_matrix_pattern=1  rgb=15:15:15
EVENT_LED_MATRIX id=27 type=CC  chn= 1 cc= 25  led_matrix_pattern=1  rgb=15:15:15
EVENT_LED_MATRIX id=28 type=CC  chn= 1 cc= 26  led_matrix_pattern=1  rgb=15:15:15
Thank you again!
Now it really works like wanted :)
Have a nice day!
