Hi Midiboxers,
Is it possible to save controller values somehow?
My exact usecase would be this:
Button 1 saves current value of encoder 1 and 2
Button 2 recalls values of encoder 1 and 2
Best regards
Marxon
I guess that you don't want to use the snapshot function, because it would store/restore all EVENT values (which are not excluded from snapshot) into/from a single storage, right?
There is a trick which could help in this case: you could use the SET command in a .NGR script to copy the value into dummy events, which don't listen or send to any MIDI port, but just act as storage units.
E.g. let's say you've defined a dummy LED with:
EVENT_LED id=3000
Then you should be able to copy the value of encoder 1 into this Event with
set LED:3000 ENC:1
And copy back with:
set ENC:1 LED:3000
in a .NGR file
Hi again,
Right!
set LED:3000 ENC:1
And copy back with:
set ENC:1 LED:3000
So that's the purpose of the set command.
I did not really figure out how the multibnk.ngc example works...
Thanks
Best regards
Marxon
But if i want to save this dummey led/enc values to sd to load them again after restart
there is no other way then using snapshots, right?
  • 2 weeks later...
Posted (edited)
A small suggestion:
What about instead to exclude controllers from dumping with "no_dump=1"
it would be nice to have the option to include controllers with "dump=1"?
Edited by Marxon
Hm... but how to switch between the different behaviours?
I guess that most people don't want to add "dump=1" to all EVENTs, so that it can only be an optional parser feature.
Yes, that´s true...
Posted (edited)
...added about 700x "no_dump=1" :smile:
Another question:
Is it possible to have different sets of controllers which get dumped?
Best regards
Marxon
EDIT:
Just an idea:
It should work if i use dummy encoders for dumping too
and copy only the required values into my "real" encoders via an meta event, or?
Edited by Marxon
Posted (edited)
Sorry for flooding the forum since a while, but this should not give the impression
that i am not trying to do it on my own. :smile:
MIOS Studio shows this error if i want to save a snapshot:
[20586.278] SAVE FX 1 1
[20586.281] [FILE] FAILURE: tried to open file '/DEFAULT.NGS' for reading, but previous file hasn't been closed!
[20586.290] [MBNG_FILE_R:455] WARNING: unknown command: p
[20586.290] [MBNG_FILE_R:456] WARNING: unknown command: p
[20586.291] [MBNG_FILE_R:457] WARNING: unknown command: "0
[20586.300] [MBNG_FILE_R:458] WARNING: unknown command: 20
[20586.300] [MBNG_FILE_R:459] WARNING: unknown command: p
[20586.301] [MBNG_FILE_R:460] WARNING: unknown command: p
[20586.302] [MBNG_FILE_R:461] WARNING: unknown command: Z4
[20586.302] [MBNG_FILE_R:462] WARNING: unknown command: 3
[20586.303] [MBNG_FILE_R:463] WARNING: unknown command: 9
[20586.308] [MBNG_FILE_R:464] WARNING: unknown command: 1
[20586.308] [MBNG_FILE_R:465] WARNING: unknown command: t
[20586.310] [MBNG_FILE_R:466] WARNING: unknown command: t
[20586.311] [MBNG_FILE_R:467] WARNING: unknown command: B8
[20586.311] [MBNG_FILE_R:468] WARNING: unknown command: 9
[20586.312] [MBNG_FILE_R:469] WARNING: unknown command: <
[20586.315] [MBNG_FILE_R:470] WARNING: unknown command: <
[20586.315] [MBNG_FILE_R:471] WARNING: unknown command:
[20586.316] [MBNG_FILE_R:472] WARNING: unknown command:
[20586.320] [MBNG_FILE_R:473] WARNING: unknown command:
[20586.320] [MBNG_FILE_R:474] WARNING: unknown command:
[20586.321] [MBNG_FILE_R:475] WARNING: unknown command:
[20586.321] [MBNG_FILE_R:476] WARNING: unknown command:
[20586.321] [MBNG_FILE_R:477] WARNING: unknown command: zc
[20586.321] [MBNG_FILE_R:478] WARNING: unknown command: d
[20586.321] [MBNG_FILE_R:479] WARNING: unknown command: d
[20586.322] [MBNG_FILE_R:480] WARNING: unknown command: tC
[20586.322] [MBNG_FILE_R:481] WARNING: unknown command: VD
[20586.323] [MBNG_FILE_R:482] WARNING: unknown command: {C
[20586.323] [MBNG_FILE_R:483] WARNING: unknown command: D
[20586.323] [MBNG_FILE_R:484] WARNING: unknown command: 'E
[20586.324] [MBNG_FILE_R:485] WARNING: unknown command: .E
[20586.324] [MBNG_FILE_R:486] WARNING: unknown command: E
[20586.324] [MBNG_FILE_R:487] WARNING: unknown command: E
[20586.324] [MBNG_FILE_R:488] WARNING: unknown command: xC
[20586.325] [MBNG_FILE_R:489] WARNING: unknown command: ZD
[20586.325] [MBNG_FILE_R:490] WARNING: unknown command: C
[20586.325] [MBNG_FILE_R:491] WARNING: unknown command: D
[20586.325] [MBNG_FILE_R:492] WARNING: unknown command: +E
[20586.325] [MBNG_FILE_R:493] WARNING: unknown command: 2E
[20586.326] [MBNG_FILE_R:494] WARNING: unknown command: E
[20586.326] [MBNG_FILE_R:495] WARNING: unknown command: E
[20586.326] [MBNG_FILE_R:496] WARNING: unknown command: cB
[20586.326] [MBNG_FILE_R:497] WARNING: unknown command: fB
[20586.327] [MBNG_FILE_R:498] WARNING: unknown command: p
[20586.327] [MBNG_FILE_R:499] WARNING: unknown command: p
[20586.327] [MBNG_FILE_R:500] WARNING: unknown command: "0
[20586.327] [MBNG_FILE_R:501] WARNING: unknown command: 20
[20586.328] [MBNG_FILE_R:502] WARNING: unknown command: p
[20586.328] [MBNG_FILE_R:503] WARNING: unknown command: p
[20586.328] [MBNG_FILE_R:504] WARNING: unknown command: Z4
[20586.328] [MBNG_FILE_R:505] WARNING: unknown command: 3
[20586.329] [MBNG_FILE_R:506] WARNING: unknown command: 9
[20586.329] [MBNG_FILE_R:507] WARNING: unknown command: 1
[20586.329] [MBNG_FILE_R:508] WARNING: unknown command: t
[20586.329] [MBNG_FILE_R:509] WARNING: unknown command: t
[20586.330] [MBNG_FILE_R:510] WARNING: unknown command: B8
[20586.336] [MBNG_FILE_R:511] WARNING: unknown command: 9
[20586.337] [MBNG_FILE_R:512] WARNING: unknown command: <
[20586.337] [MBNG_FILE_R:513] WARNING: unknown command: <
[20586.337] [MBNG_FILE_R:514] WARNING: unknown command:
[20586.337] [MBNG_FILE_R:515] WARNING: unknown command:
[20586.338] [MBNG_FILE_R:516] WARNING: unknown command:
[20586.338] [MBNG_FILE_R:517] WARNING: unknown command:
[20586.338] [MBNG_FILE_R:518] WARNING: unknown command:
[20586.338] [MBNG_FILE_R:519] WARNING: unknown command:
[20586.338] [MBNG_FILE_R:520] WARNING: unknown command: zc
[20586.339] [MBNG_FILE_R:521] WARNING: unknown command: d
[20586.340] [MBNG_FILE_R:522] WARNING: unknown command: d
[20586.340] [MBNG_FILE_R:523] WARNING: unknown command: tC
[20586.340] [MBNG_FILE_R:524] WARNING: unknown command: VD
[20586.342] [MBNG_FILE_R:525] WARNING: unknown command: {C
[20586.342] [MBNG_FILE_R:526] WARNING: unknown command: D
[20586.342] [MBNG_FILE_R:527] WARNING: unknown command: 'E
[20586.343] [MBNG_FILE_R:528] WARNING: unknown command: .E
[20586.343] [MBNG_FILE_R:529] WARNING: unknown command: E
[20586.343] [MBNG_FILE_R:530] WARNING: unknown command: E
[20586.343] [MBNG_FILE_R:531] WARNING: unknown command: xC
[20586.344] [MBNG_FILE_R:532] WARNING: unknown command: ZD
[20586.345] [MBNG_FILE_R:533] WARNING: unknown command: C
[20586.345] [MBNG_FILE_R:534] WARNING: unknown command: D
[20586.345] [MBNG_FILE_R:535] WARNING: unknown command: +E
[20586.347] [MBNG_FILE_R:536] WARNING: unknown command: 2E
[20586.347] [MBNG_FILE_R:537] WARNING: unknown command: E
[20586.348] [MBNG_FILE_R:538] WARNING: unknown command: E
[20586.348] [MBNG_FILE_R:539] WARNING: unknown command: cB
[20586.349] [MBNG_FILE_R:540] WARNING: unknown command: fB
[20586.350] [MBNG_FILE_R:541] WARNING: unknown command: p
[20586.350] [MBNG_FILE_R:542] WARNING: unknown command: p
[20586.352] [MBNG_FILE_R:543] WARNING: unknown command: "0
[20586.352] [MBNG_FILE_R:544] WARNING: unknown command: 20
[20586.353] [MBNG_FILE_R:545] WARNING: unknown command: p
[20586.354] [MBNG_FILE_R:546] WARNING: unknown command: p
[20586.355] [MBNG_FILE_R:547] WARNING: unknown command: Z4
[20586.355] [MBNG_FILE_R:548] WARNING: unknown command: 3
[20586.356] [MBNG_FILE_R:549] WARNING: unknown command: 9
[20586.359] [MBNG_FILE_R:550] WARNING: unknown command: 1
[20586.360] [MBNG_FILE_R:551] WARNING: unknown command: t
[20586.360] [MBNG_FILE_R:552] WARNING: unknown command: t
[20586.364] [MBNG_FILE_R:553] WARNING: unknown command: B8
[20586.366] [MBNG_FILE_R:554] WARNING: unknown command: 9
[20586.366] [MBNG_FILE_R:555] WARNING: unknown command: <
[20586.367] [MBNG_FILE_R:556] WARNING: unknown command: <
[20586.368] [MBNG_FILE_R:557] WARNING: unknown command:
[20586.368] [MBNG_FILE_R:558] WARNING: unknown command:
[20586.368] [MBNG_FILE_R:559] WARNING: unknown command:
[20586.369] [MBNG_FILE_R:560] WARNING: unknown command:
[20586.370] [MBNG_FILE_R:561] WARNING: unknown command:
[20586.371] [MBNG_FILE_R:562] WARNING: unknown command:
[20586.371] [MBNG_FILE_R:563] WARNING: unknown command: zc
[20586.372] [MBNG_FILE_R:564] WARNING: unknown command: d
[20586.372] [MBNG_FILE_R:565] WARNING: unknown command: d
[20586.372] [MBNG_FILE_R:566] WARNING: unknown command: tC
[20586.372] [MBNG_FILE_R:567] WARNING: unknown command: VD
[20586.372] [MBNG_FILE_R:568] WARNING: unknown command: {C
[20586.373] [MBNG_FILE_R:569] WARNING: unknown command: D
[20586.373] [MBNG_FILE_R:570] WARNING: unknown command: 'E
[20586.374] [MBNG_FILE_R:571] WARNING: unknown command: .E
[20586.374] [MBNG_FILE_R:572] WARNING: unknown command: E
[20586.374] [MBNG_FILE_R:573] WARNING: unknown command: E
[20586.375] [MBNG_FILE_R:574] WARNING: unknown command: xC
[20586.375] [MBNG_FILE_R:575] WARNING: unknown command: ZD
[20586.375] [MBNG_FILE_R:576] WARNING: unknown command: C
[20586.376] [MBNG_FILE_R:577] WARNING: unknown command: D
[20586.376] [MBNG_FILE_R:578] WARNING: unknown command: +E
[20586.377] [MBNG_FILE_R:579] WARNING: unknown command: 2E
[20586.377] [MBNG_FILE_R:580] WARNING: unknown command: E
[20586.377] [MBNG_FILE_R:581] WARNING: unknown command: E
[20586.378] [MBNG_FILE_R:582] WARNING: unknown command: cB
[20586.380] [MBNG_FILE_R:583] WARNING: unknown command: fB
[20586.381] [MBNG_FILE_R:584] WARNING: unknown command: p
[20586.382] [MBNG_FILE_R:585] WARNING: unknown command: p
[20586.382] [MBNG_FILE_R:586] WARNING: unknown command: "0
[20586.383] [MBNG_FILE_R:587] WARNING: unknown command: 20
[20586.386] [MBNG_FILE_R:588] WARNING: unknown command: p
[20586.387] [MBNG_FILE_R:589] WARNING: unknown command: p
[20586.387] [MBNG_FILE_R:590] WARNING: unknown command: Z4
[20586.387] [MBNG_FILE_R:591] WARNING: unknown command: 3
[20586.388] [MBNG_FILE_R:592] WARNING: unknown command: 9
[20586.391] [MBNG_FILE_R:593] WARNING: unknown command: 1
[20586.391] [MBNG_FILE_R:594] WARNING: unknown command: t
[20586.392] [MBNG_FILE_R:595] WARNING: unknown command: t
[20586.394] [MBNG_FILE_R:596] WARNING: unknown command: B8
[20586.398] [MBNG_FILE_R:597] WARNING: unknown command: 9
[20586.398] [MBNG_FILE_R:598] WARNING: unknown command: <
[20586.398] [MBNG_FILE_R:599] WARNING: unknown command: <
[20586.399] [MBNG_FILE_R:600] WARNING: unknown command:
[20586.399] [MBNG_FILE_R:601] WARNING: unknown command:
[20586.400] [MBNG_FILE_R:602] WARNING: unknown command:
[20586.400] [MBNG_FILE_R:603] WARNING: unknown command:
[20586.400] [MBNG_FILE_R:604] WARNING: unknown command:
[20586.401] [MBNG_FILE_R:605] WARNING: unknown command:
[20586.402] [MBNG_FILE_R:606] WARNING: unknown command: zc
[20586.403] [MBNG_FILE_R:607] WARNING: unknown command: d
[20586.403] [MBNG_FILE_R:608] WARNING: unknown command: d
[20586.403] [MBNG_FILE_R:609] WARNING: unknown command: tC
[20586.404] [MBNG_FILE_R:610] WARNING: unknown command: VD
[20586.404] [MBNG_FILE_R:611] WARNING: unknown command: {C
[20586.404] [MBNG_FILE_R:612] WARNING: unknown command: D
[20586.405] [MBNG_FILE_R:613] WARNING: unknown command: 'E
[20586.405] [MBNG_FILE_R:614] WARNING: unknown command: .E
[20586.405] [MBNG_FILE_R:615] WARNING: unknown command: E
[20586.406] [MBNG_FILE_R:616] WARNING: unknown command: E
[20586.406] [MBNG_FILE_R:617] WARNING: unknown command: xC
[20586.407] [MBNG_FILE_R:618] WARNING: unknown command: ZD
[20586.407] [MBNG_FILE_R:619] WARNING: unknown command: C
[20586.407] [MBNG_FILE_R:620] WARNING: unknown command: D
[20586.408] [MBNG_FILE_R:621] WARNING: unknown command: +E
[20586.409] [MBNG_FILE_R:622] WARNING: unknown command: 2E
[20586.409] [MBNG_FILE_R:623] WARNING: unknown command: E
[20586.409] [MBNG_FILE_R:624] WARNING: unknown command: E
[20586.410] [MBNG_FILE_R:625] WARNING: unknown command: cB
[20586.411] [MBNG_FILE_R:626] WARNING: unknown command: fB
[20586.413] [MBNG_FILE_R:627] WARNING: unknown command: p
[20586.414] [MBNG_FILE_R:628] WARNING: unknown command: p
[20586.414] [MBNG_FILE_R:629] WARNING: unknown command: "0
[20586.415] [MBNG_FILE_R:630] WARNING: unknown command: 20
[20586.419] [MBNG_FILE_R:631] WARNING: unknown command: p
[20586.419] [MBNG_FILE_R:632] WARNING: unknown command: p
[20586.420] [MBNG_FILE_R:633] WARNING: unknown command: Z4
[20586.420] [MBNG_FILE_R:634] WARNING: unknown command: 3
[20586.420] [MBNG_FILE_R:635] WARNING: unknown command: 9
[20586.422] [MBNG_FILE_R:636] WARNING: unknown command: 1
[20586.422] [MBNG_FILE_R:637] WARNING: unknown command: t
[20586.424] [MBNG_FILE_R:638] WARNING: unknown command: t
[20586.426] [MBNG_FILE_R:639] WARNING: unknown command: B8
[20586.429] [MBNG_FILE_R:640] WARNING: unknown command: 9
[20586.429] [MBNG_FILE_R:641] WARNING: unknown command: <
[20586.430] [MBNG_FILE_R:642] WARNING: unknown command: <
[20586.431] [MBNG_FILE_R:643] WARNING: unknown command:
[20586.431] [MBNG_FILE_R:644] WARNING: unknown command:
[20586.431] [MBNG_FILE_R:645] WARNING: unknown command:
[20586.431] [MBNG_FILE_R:646] WARNING: unknown command:
[20586.432] [MBNG_FILE_R:647] WARNING: unknown command:
[20586.433] [MBNG_FILE_R:648] WARNING: unknown command:
[20586.433] [MBNG_FILE_R:649] WARNING: unknown command: zc
[20586.433] [MBNG_FILE_R:650] WARNING: unknown command: d
[20586.434] [MBNG_FILE_R:651] WARNING: unknown command: d
[20586.435] [MBNG_FILE_R:652] WARNING: unknown command: tC
[20586.435] [MBNG_FILE_R:653] WARNING: unknown command: VD
[20586.435] [MBNG_FILE_R:654] WARNING: unknown command: {C
[20586.436] [MBNG_FILE_R:655] WARNING: unknown command: D
[20586.437] [MBNG_FILE_R:656] WARNING: unknown command: 'E
[20586.437] [MBNG_FILE_R:657] WARNING: unknown command: .E
[20586.437] [MBNG_FILE_R:658] WARNING: unknown command: E
[20586.437] [MBNG_FILE_R:659] WARNING: unknown command: E
[20586.438] [MBNG_FILE_R:660] WARNING: unknown command: xC
[20586.438] [MBNG_FILE_R:661] WARNING: unknown command: ZD
[20586.438] [MBNG_FILE_R:662] WARNING: unknown command: C
[20586.439] [MBNG_FILE_R:663] WARNING: unknown command: D
[20586.439] [MBNG_FILE_R:664] WARNING: unknown command: +E
[20586.440] [MBNG_FILE_R:665] WARNING: unknown command: 2E
[20586.440] [MBNG_FILE_R:666] WARNING: unknown command: E
[20586.440] [MBNG_FILE_R:667] WARNING: unknown command: E
[20586.441] [MBNG_FILE_R:668] WARNING: unknown command: cB
[20586.441] [MBNG_FILE_R:669] WARNING: unknown command: fB
[20586.442] [MBNG_FILE_R:670] WARNING: missing ENDIF command!
I use this code to save snapshot:
.ngc
EVENT_BUTTON  id=2517  hw_id=1024	if_equal=button:2088:127	type=meta 	 meta=runsection:71 no_dump=1
.ngr
# LINE 450
if ^section == 71
	LOG "SAVE FX 1 1"
	exec_meta SetSnapshot 1
	exec_meta SaveSnapshot
endif
Whats wrong?
Thanks again for support!
Best regards
Marxon
Edited by Marxon
We've a problem here: the application can only open one file (because there is only a single read buffer).
This was never a problem before, but now you found a case where it does matter.
I've to consider to overwork the file handling to cover this case, but this will be a complicated change, and I won't have the time to do this in the next 3..4 weeks... :-/
Does it work if i put everything (set, load, dump a snapshot and trigger a runsection)
into one single .ngc meta event?
