Marxon Posted December 26, 2013 Report Share Posted December 26, 2013 Hi Midiboxers, Is it possible to save controller values somehow? My exact usecase would be this: Button 1 saves current value of encoder 1 and 2 Button 2 recalls values of encoder 1 and 2 Best regards Marxon Quote Link to comment Share on other sites More sharing options...
TK. Posted December 26, 2013 Report Share Posted December 26, 2013 I guess that you don't want to use the snapshot function, because it would store/restore all EVENT values (which are not excluded from snapshot) into/from a single storage, right? There is a trick which could help in this case: you could use the SET command in a .NGR script to copy the value into dummy events, which don't listen or send to any MIDI port, but just act as storage units. E.g. let's say you've defined a dummy LED with:EVENT_LED id=3000Then you should be able to copy the value of encoder 1 into this Event withset LED:3000 ENC:1And copy back with:set ENC:1 LED:3000in a .NGR file Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted December 27, 2013 Author Report Share Posted December 27, 2013 Hi again, I guess that you don't want to use the snapshot function, because it would store/restore all EVENT values (which are not excluded from snapshot) into/from a single storage, right? Right! Then you should be able to copy the value of encoder 1 into this Event with set LED:3000 ENC:1 And copy back with: set ENC:1 LED:3000 So that's the purpose of the set command. I did not really figure out how the multibnk.ngc example works... Thanks Best regards Marxon Quote Link to comment Share on other sites More sharing options...
Marxon Posted December 30, 2013 Author Report Share Posted December 30, 2013 But if i want to save this dummey led/enc values to sd to load them again after restart there is no other way then using snapshots, right? Quote Link to comment Share on other sites More sharing options...
TK. Posted December 30, 2013 Report Share Posted December 30, 2013 Yes, this can only be done with snapshots. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted January 9, 2014 Author Report Share Posted January 9, 2014 (edited) A small suggestion: What about instead to exclude controllers from dumping with "no_dump=1" it would be nice to have the option to include controllers with "dump=1"? Edited January 9, 2014 by Marxon Quote Link to comment Share on other sites More sharing options...
TK. Posted January 11, 2014 Report Share Posted January 11, 2014 Hm... but how to switch between the different behaviours? I guess that most people don't want to add "dump=1" to all EVENTs, so that it can only be an optional parser feature. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted January 11, 2014 Author Report Share Posted January 11, 2014 I guess that most people don't want to add "dump=1" to all EVENTs, so that it can only be an optional parser feature. Yes, that´s true... Quote Link to comment Share on other sites More sharing options...
Marxon Posted January 16, 2014 Author Report Share Posted January 16, 2014 (edited) ...added about 700x "no_dump=1" :smile: Another question: Is it possible to have different sets of controllers which get dumped? Best regards Marxon EDIT: Just an idea: It should work if i use dummy encoders for dumping too and copy only the required values into my "real" encoders via an meta event, or? Edited January 16, 2014 by Marxon Quote Link to comment Share on other sites More sharing options...
Marxon Posted January 18, 2014 Author Report Share Posted January 18, 2014 (edited) Sorry for flooding the forum since a while, but this should not give the impression that i am not trying to do it on my own. :smile: MIOS Studio shows this error if i want to save a snapshot: [20586.278] SAVE FX 1 1 [20586.281] [FILE] FAILURE: tried to open file '/DEFAULT.NGS' for reading, but previous file hasn't been closed! [20586.290] [MBNG_FILE_R:455] WARNING: unknown command: p [20586.290] [MBNG_FILE_R:456] WARNING: unknown command: p [20586.291] [MBNG_FILE_R:457] WARNING: unknown command: "0 [20586.300] [MBNG_FILE_R:458] WARNING: unknown command: 20 [20586.300] [MBNG_FILE_R:459] WARNING: unknown command: p [20586.301] [MBNG_FILE_R:460] WARNING: unknown command: p [20586.302] [MBNG_FILE_R:461] WARNING: unknown command: Z4 [20586.302] [MBNG_FILE_R:462] WARNING: unknown command: 3 [20586.303] [MBNG_FILE_R:463] WARNING: unknown command: 9 [20586.308] [MBNG_FILE_R:464] WARNING: unknown command: 1 [20586.308] [MBNG_FILE_R:465] WARNING: unknown command: t [20586.310] [MBNG_FILE_R:466] WARNING: unknown command: t [20586.311] [MBNG_FILE_R:467] WARNING: unknown command: B8 [20586.311] [MBNG_FILE_R:468] WARNING: unknown command: 9 [20586.312] [MBNG_FILE_R:469] WARNING: unknown command: < [20586.315] [MBNG_FILE_R:470] WARNING: unknown command: < [20586.315] [MBNG_FILE_R:471] WARNING: unknown command: [20586.316] [MBNG_FILE_R:472] WARNING: unknown command: [20586.320] [MBNG_FILE_R:473] WARNING: unknown command: [20586.320] [MBNG_FILE_R:474] WARNING: unknown command: [20586.321] [MBNG_FILE_R:475] WARNING: unknown command: [20586.321] [MBNG_FILE_R:476] WARNING: unknown command: [20586.321] [MBNG_FILE_R:477] WARNING: unknown command: zc [20586.321] [MBNG_FILE_R:478] WARNING: unknown command: d [20586.321] [MBNG_FILE_R:479] WARNING: unknown command: d [20586.322] [MBNG_FILE_R:480] WARNING: unknown command: tC [20586.322] [MBNG_FILE_R:481] WARNING: unknown command: VD [20586.323] [MBNG_FILE_R:482] WARNING: unknown command: {C [20586.323] [MBNG_FILE_R:483] WARNING: unknown command: D [20586.323] [MBNG_FILE_R:484] WARNING: unknown command: 'E [20586.324] [MBNG_FILE_R:485] WARNING: unknown command: .E [20586.324] [MBNG_FILE_R:486] WARNING: unknown command: E [20586.324] [MBNG_FILE_R:487] WARNING: unknown command: E [20586.324] [MBNG_FILE_R:488] WARNING: unknown command: xC [20586.325] [MBNG_FILE_R:489] WARNING: unknown command: ZD [20586.325] [MBNG_FILE_R:490] WARNING: unknown command: C [20586.325] [MBNG_FILE_R:491] WARNING: unknown command: D [20586.325] [MBNG_FILE_R:492] WARNING: unknown command: +E [20586.325] [MBNG_FILE_R:493] WARNING: unknown command: 2E [20586.326] [MBNG_FILE_R:494] WARNING: unknown command: E [20586.326] [MBNG_FILE_R:495] WARNING: unknown command: E [20586.326] [MBNG_FILE_R:496] WARNING: unknown command: cB [20586.326] [MBNG_FILE_R:497] WARNING: unknown command: fB [20586.327] [MBNG_FILE_R:498] WARNING: unknown command: p [20586.327] [MBNG_FILE_R:499] WARNING: unknown command: p [20586.327] [MBNG_FILE_R:500] WARNING: unknown command: "0 [20586.327] [MBNG_FILE_R:501] WARNING: unknown command: 20 [20586.328] [MBNG_FILE_R:502] WARNING: unknown command: p [20586.328] [MBNG_FILE_R:503] WARNING: unknown command: p [20586.328] [MBNG_FILE_R:504] WARNING: unknown command: Z4 [20586.328] [MBNG_FILE_R:505] WARNING: unknown command: 3 [20586.329] [MBNG_FILE_R:506] WARNING: unknown command: 9 [20586.329] [MBNG_FILE_R:507] WARNING: unknown command: 1 [20586.329] [MBNG_FILE_R:508] WARNING: unknown command: t [20586.329] [MBNG_FILE_R:509] WARNING: unknown command: t [20586.330] [MBNG_FILE_R:510] WARNING: unknown command: B8 [20586.336] [MBNG_FILE_R:511] WARNING: unknown command: 9 [20586.337] [MBNG_FILE_R:512] WARNING: unknown command: < [20586.337] [MBNG_FILE_R:513] WARNING: unknown command: < [20586.337] [MBNG_FILE_R:514] WARNING: unknown command: [20586.337] [MBNG_FILE_R:515] WARNING: unknown command: [20586.338] [MBNG_FILE_R:516] WARNING: unknown command: [20586.338] [MBNG_FILE_R:517] WARNING: unknown command: [20586.338] [MBNG_FILE_R:518] WARNING: unknown command: [20586.338] [MBNG_FILE_R:519] WARNING: unknown command: [20586.338] [MBNG_FILE_R:520] WARNING: unknown command: zc [20586.339] [MBNG_FILE_R:521] WARNING: unknown command: d [20586.340] [MBNG_FILE_R:522] WARNING: unknown command: d [20586.340] [MBNG_FILE_R:523] WARNING: unknown command: tC [20586.340] [MBNG_FILE_R:524] WARNING: unknown command: VD [20586.342] [MBNG_FILE_R:525] WARNING: unknown command: {C [20586.342] [MBNG_FILE_R:526] WARNING: unknown command: D [20586.342] [MBNG_FILE_R:527] WARNING: unknown command: 'E [20586.343] [MBNG_FILE_R:528] WARNING: unknown command: .E [20586.343] [MBNG_FILE_R:529] WARNING: unknown command: E [20586.343] [MBNG_FILE_R:530] WARNING: unknown command: E [20586.343] [MBNG_FILE_R:531] WARNING: unknown command: xC [20586.344] [MBNG_FILE_R:532] WARNING: unknown command: ZD [20586.345] [MBNG_FILE_R:533] WARNING: unknown command: C [20586.345] [MBNG_FILE_R:534] WARNING: unknown command: D [20586.345] [MBNG_FILE_R:535] WARNING: unknown command: +E [20586.347] [MBNG_FILE_R:536] WARNING: unknown command: 2E [20586.347] [MBNG_FILE_R:537] WARNING: unknown command: E [20586.348] [MBNG_FILE_R:538] WARNING: unknown command: E [20586.348] [MBNG_FILE_R:539] WARNING: unknown command: cB [20586.349] [MBNG_FILE_R:540] WARNING: unknown command: fB [20586.350] [MBNG_FILE_R:541] WARNING: unknown command: p [20586.350] [MBNG_FILE_R:542] WARNING: unknown command: p [20586.352] [MBNG_FILE_R:543] WARNING: unknown command: "0 [20586.352] [MBNG_FILE_R:544] WARNING: unknown command: 20 [20586.353] [MBNG_FILE_R:545] WARNING: unknown command: p [20586.354] [MBNG_FILE_R:546] WARNING: unknown command: p [20586.355] [MBNG_FILE_R:547] WARNING: unknown command: Z4 [20586.355] [MBNG_FILE_R:548] WARNING: unknown command: 3 [20586.356] [MBNG_FILE_R:549] WARNING: unknown command: 9 [20586.359] [MBNG_FILE_R:550] WARNING: unknown command: 1 [20586.360] [MBNG_FILE_R:551] WARNING: unknown command: t [20586.360] [MBNG_FILE_R:552] WARNING: unknown command: t [20586.364] [MBNG_FILE_R:553] WARNING: unknown command: B8 [20586.366] [MBNG_FILE_R:554] WARNING: unknown command: 9 [20586.366] [MBNG_FILE_R:555] WARNING: unknown command: < [20586.367] [MBNG_FILE_R:556] WARNING: unknown command: < [20586.368] [MBNG_FILE_R:557] WARNING: unknown command: [20586.368] [MBNG_FILE_R:558] WARNING: unknown command: [20586.368] [MBNG_FILE_R:559] WARNING: unknown command: [20586.369] [MBNG_FILE_R:560] WARNING: unknown command: [20586.370] [MBNG_FILE_R:561] WARNING: unknown command: [20586.371] [MBNG_FILE_R:562] WARNING: unknown command: [20586.371] [MBNG_FILE_R:563] WARNING: unknown command: zc [20586.372] [MBNG_FILE_R:564] WARNING: unknown command: d [20586.372] [MBNG_FILE_R:565] WARNING: unknown command: d [20586.372] [MBNG_FILE_R:566] WARNING: unknown command: tC [20586.372] [MBNG_FILE_R:567] WARNING: unknown command: VD [20586.372] [MBNG_FILE_R:568] WARNING: unknown command: {C [20586.373] [MBNG_FILE_R:569] WARNING: unknown command: D [20586.373] [MBNG_FILE_R:570] WARNING: unknown command: 'E [20586.374] [MBNG_FILE_R:571] WARNING: unknown command: .E [20586.374] [MBNG_FILE_R:572] WARNING: unknown command: E [20586.374] [MBNG_FILE_R:573] WARNING: unknown command: E [20586.375] [MBNG_FILE_R:574] WARNING: unknown command: xC [20586.375] [MBNG_FILE_R:575] WARNING: unknown command: ZD [20586.375] [MBNG_FILE_R:576] WARNING: unknown command: C [20586.376] [MBNG_FILE_R:577] WARNING: unknown command: D [20586.376] [MBNG_FILE_R:578] WARNING: unknown command: +E [20586.377] [MBNG_FILE_R:579] WARNING: unknown command: 2E [20586.377] [MBNG_FILE_R:580] WARNING: unknown command: E [20586.377] [MBNG_FILE_R:581] WARNING: unknown command: E [20586.378] [MBNG_FILE_R:582] WARNING: unknown command: cB [20586.380] [MBNG_FILE_R:583] WARNING: unknown command: fB [20586.381] [MBNG_FILE_R:584] WARNING: unknown command: p [20586.382] [MBNG_FILE_R:585] WARNING: unknown command: p [20586.382] [MBNG_FILE_R:586] WARNING: unknown command: "0 [20586.383] [MBNG_FILE_R:587] WARNING: unknown command: 20 [20586.386] [MBNG_FILE_R:588] WARNING: unknown command: p [20586.387] [MBNG_FILE_R:589] WARNING: unknown command: p [20586.387] [MBNG_FILE_R:590] WARNING: unknown command: Z4 [20586.387] [MBNG_FILE_R:591] WARNING: unknown command: 3 [20586.388] [MBNG_FILE_R:592] WARNING: unknown command: 9 [20586.391] [MBNG_FILE_R:593] WARNING: unknown command: 1 [20586.391] [MBNG_FILE_R:594] WARNING: unknown command: t [20586.392] [MBNG_FILE_R:595] WARNING: unknown command: t [20586.394] [MBNG_FILE_R:596] WARNING: unknown command: B8 [20586.398] [MBNG_FILE_R:597] WARNING: unknown command: 9 [20586.398] [MBNG_FILE_R:598] WARNING: unknown command: < [20586.398] [MBNG_FILE_R:599] WARNING: unknown command: < [20586.399] [MBNG_FILE_R:600] WARNING: unknown command: [20586.399] [MBNG_FILE_R:601] WARNING: unknown command: [20586.400] [MBNG_FILE_R:602] WARNING: unknown command: [20586.400] [MBNG_FILE_R:603] WARNING: unknown command: [20586.400] [MBNG_FILE_R:604] WARNING: unknown command: [20586.401] [MBNG_FILE_R:605] WARNING: unknown command: [20586.402] [MBNG_FILE_R:606] WARNING: unknown command: zc [20586.403] [MBNG_FILE_R:607] WARNING: unknown command: d [20586.403] [MBNG_FILE_R:608] WARNING: unknown command: d [20586.403] [MBNG_FILE_R:609] WARNING: unknown command: tC [20586.404] [MBNG_FILE_R:610] WARNING: unknown command: VD [20586.404] [MBNG_FILE_R:611] WARNING: unknown command: {C [20586.404] [MBNG_FILE_R:612] WARNING: unknown command: D [20586.405] [MBNG_FILE_R:613] WARNING: unknown command: 'E [20586.405] [MBNG_FILE_R:614] WARNING: unknown command: .E [20586.405] [MBNG_FILE_R:615] WARNING: unknown command: E [20586.406] [MBNG_FILE_R:616] WARNING: unknown command: E [20586.406] [MBNG_FILE_R:617] WARNING: unknown command: xC [20586.407] [MBNG_FILE_R:618] WARNING: unknown command: ZD [20586.407] [MBNG_FILE_R:619] WARNING: unknown command: C [20586.407] [MBNG_FILE_R:620] WARNING: unknown command: D [20586.408] [MBNG_FILE_R:621] WARNING: unknown command: +E [20586.409] [MBNG_FILE_R:622] WARNING: unknown command: 2E [20586.409] [MBNG_FILE_R:623] WARNING: unknown command: E [20586.409] [MBNG_FILE_R:624] WARNING: unknown command: E [20586.410] [MBNG_FILE_R:625] WARNING: unknown command: cB [20586.411] [MBNG_FILE_R:626] WARNING: unknown command: fB [20586.413] [MBNG_FILE_R:627] WARNING: unknown command: p [20586.414] [MBNG_FILE_R:628] WARNING: unknown command: p [20586.414] [MBNG_FILE_R:629] WARNING: unknown command: "0 [20586.415] [MBNG_FILE_R:630] WARNING: unknown command: 20 [20586.419] [MBNG_FILE_R:631] WARNING: unknown command: p [20586.419] [MBNG_FILE_R:632] WARNING: unknown command: p [20586.420] [MBNG_FILE_R:633] WARNING: unknown command: Z4 [20586.420] [MBNG_FILE_R:634] WARNING: unknown command: 3 [20586.420] [MBNG_FILE_R:635] WARNING: unknown command: 9 [20586.422] [MBNG_FILE_R:636] WARNING: unknown command: 1 [20586.422] [MBNG_FILE_R:637] WARNING: unknown command: t [20586.424] [MBNG_FILE_R:638] WARNING: unknown command: t [20586.426] [MBNG_FILE_R:639] WARNING: unknown command: B8 [20586.429] [MBNG_FILE_R:640] WARNING: unknown command: 9 [20586.429] [MBNG_FILE_R:641] WARNING: unknown command: < [20586.430] [MBNG_FILE_R:642] WARNING: unknown command: < [20586.431] [MBNG_FILE_R:643] WARNING: unknown command: [20586.431] [MBNG_FILE_R:644] WARNING: unknown command: [20586.431] [MBNG_FILE_R:645] WARNING: unknown command: [20586.431] [MBNG_FILE_R:646] WARNING: unknown command: [20586.432] [MBNG_FILE_R:647] WARNING: unknown command: [20586.433] [MBNG_FILE_R:648] WARNING: unknown command: [20586.433] [MBNG_FILE_R:649] WARNING: unknown command: zc [20586.433] [MBNG_FILE_R:650] WARNING: unknown command: d [20586.434] [MBNG_FILE_R:651] WARNING: unknown command: d [20586.435] [MBNG_FILE_R:652] WARNING: unknown command: tC [20586.435] [MBNG_FILE_R:653] WARNING: unknown command: VD [20586.435] [MBNG_FILE_R:654] WARNING: unknown command: {C [20586.436] [MBNG_FILE_R:655] WARNING: unknown command: D [20586.437] [MBNG_FILE_R:656] WARNING: unknown command: 'E [20586.437] [MBNG_FILE_R:657] WARNING: unknown command: .E [20586.437] [MBNG_FILE_R:658] WARNING: unknown command: E [20586.437] [MBNG_FILE_R:659] WARNING: unknown command: E [20586.438] [MBNG_FILE_R:660] WARNING: unknown command: xC [20586.438] [MBNG_FILE_R:661] WARNING: unknown command: ZD [20586.438] [MBNG_FILE_R:662] WARNING: unknown command: C [20586.439] [MBNG_FILE_R:663] WARNING: unknown command: D [20586.439] [MBNG_FILE_R:664] WARNING: unknown command: +E [20586.440] [MBNG_FILE_R:665] WARNING: unknown command: 2E [20586.440] [MBNG_FILE_R:666] WARNING: unknown command: E [20586.440] [MBNG_FILE_R:667] WARNING: unknown command: E [20586.441] [MBNG_FILE_R:668] WARNING: unknown command: cB [20586.441] [MBNG_FILE_R:669] WARNING: unknown command: fB [20586.442] [MBNG_FILE_R:670] WARNING: missing ENDIF command! I use this code to save snapshot: .ngc EVENT_BUTTON id=2517 hw_id=1024 if_equal=button:2088:127 type=meta meta=runsection:71 no_dump=1 .ngr # LINE 450 if ^section == 71 LOG "SAVE FX 1 1" exec_meta SetSnapshot 1 exec_meta SaveSnapshot endif Whats wrong? Thanks again for support! Best regards Marxon Edited January 18, 2014 by Marxon Quote Link to comment Share on other sites More sharing options...
TK. Posted January 19, 2014 Report Share Posted January 19, 2014 We've a problem here: the application can only open one file (because there is only a single read buffer). This was never a problem before, but now you found a case where it does matter. I've to consider to overwork the file handling to cover this case, but this will be a complicated change, and I won't have the time to do this in the next 3..4 weeks... :-/ Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted January 19, 2014 Author Report Share Posted January 19, 2014 Open one file? Do you mean it is not possible to use a script (.ngr) to load a snapshot (.ngs)? Quote Link to comment Share on other sites More sharing options...
TK. Posted January 19, 2014 Report Share Posted January 19, 2014 Yes Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted January 19, 2014 Author Report Share Posted January 19, 2014 Does it work if i put everything (set, load, dump a snapshot and trigger a runsection) into one single .ngc meta event? Quote Link to comment Share on other sites More sharing options...
TK. Posted January 19, 2014 Report Share Posted January 19, 2014 Yes, this should work. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
