Hi all,
I did not notice when this behavior started but
since recently when i push certain buttons then some led go off.
They go on again when a corresponding event is triggerd.
This happens only on inputs at
din_sr=3 d7-d4
din_sr=4 d7-d0
din_sr=5 d7-d0 and
din_sr=6 d7-d4
Only outputs at
dout_sr=15 and
dout_sr=16 are affected.
This circuits are electrical not related to each other.
For debugging i:
-diconnected all buttons/encoders from the relevant dins
-deleted all unnecessary events in the .ngc and .ngr files
-used some other din board
But the problem still occurs...
What could be the reason?
Thanks for any suggestion!
Best regards
Marxon
Edited by Marxon
Hi again
i localized the problem:
Really wired...
This is my .ngc
DOUT_MATRIX n=5   rows=4   sr_dout_sel1=14	sr_dout_g1=16 sr_dout_b1=17 sr_dout_r1=15 led_emu_id_offset=1001
EVENT_BUTTON id=127 hw_id= 27 type=CC Bank=12 chn= 1 cc=22 range=0:127 lcd_pos=1:1:1
EVENT_BUTTON id=29  hw_id=29  type=meta	meta=SetBank	range=1:11 lcd_pos=1:1:1  button_mode=ononly
EVENT_LED	id=1001	hw_id=1001	type=NoteOn	key= 1	chn=11	Rgb=12:15:0
EVENT_LED	id=1002	hw_id=1002	type=NoteOn	key= 3	chn=11	Rgb=12:15:0
EVENT_LED	id=1003	hw_id=1003	type=NoteOn	key= 5	chn=11	Rgb=12:15:0
EVENT_LED	id=1004	hw_id=1004	type=NoteOn	key= 7	chn=11	Rgb=12:15:0
EVENT_LED	id=1009	hw_id=1009	type=NoteOn	key= 9	chn=11	Rgb=12:15:0
EVENT_LED	id=1010	hw_id=1010	type=NoteOn	key=11	chn=11	Rgb=12:15:0
EVENT_LED	id=1011	hw_id=1011	type=NoteOn	key=13	chn=11	Rgb=12:15:0
EVENT_LED	id=1012	hw_id=1012	type=NoteOn	key=15	chn=11	Rgb=12:15:0
EVENT_LED	id=1101	hw_id=1001	type=NoteOn	key= 2	chn=11 	Rgb=15:4:0
EVENT_LED	id=1102	hw_id=1002	type=NoteOn	key= 4	chn=11 	Rgb=15:4:0
EVENT_LED	id=1103	hw_id=1003	type=NoteOn	key= 6	chn=11 	Rgb=15:4:0
EVENT_LED	id=1104	hw_id=1004	type=NoteOn	key= 8	chn=11 	Rgb=15:4:0
EVENT_LED	id=1109	hw_id=1009	type=NoteOn	key=10	chn=11 	Rgb=15:4:0
EVENT_LED	id=1110	hw_id=1010	type=NoteOn	key=12	chn=11 	Rgb=15:4:0
EVENT_LED	id=1111	hw_id=1011	type=NoteOn	key=14	chn=11 	Rgb=15:4:0
EVENT_LED	id=1112	hw_id=1012	type=NoteOn	key=16	chn=11 	Rgb=15:4:0
Test 1:
led(id)=1001 and led(id)=1102 are on ->
press button(idd)=127 ->
led(id)=1001 out
led(id)=1102 on
Test 2:
led(id)=1001 and led(id)=1002 are on ->
led(id)=1001 out
led(id)=1002 out
It only happens if both button events are active.
If one of the button events is deactivated (#) then everything work without problems.
Edited by Marxon
Unfortunately this is not not the reason...
Here i have some other example:
DOUT_MATRIX n=8  rows=4  sr_dout_sel1=6  sr_dout_r1=7 sr_dout_g1=9  sr_dout_b1=8 led_emu_id_offset=601
EVENT_led id=645 hw_id=609 type=NoteOn key=45 chn=6  Rgb=0:0:15 no_dump=1
DIN_MATRIX n=1 rows=8 sr_dout_sel1=1  sr_din1=1 button_emu_id_offset=1001
EVENT_BUTTON id=2117 hw_id=1040 type=NoteOn chn=1 key=17 no_dump=1
EVENT_BUTTON id=29 hw_id=29 range=1:1 button_mode=ononly type=Meta meta=setbank
-> LED id=645 is turned on via external midi
-> Pressing Button id=29 turns off LED id=645 and all other leds fromthis matrix.
If i use this code standalone then it works,
but together with all my other code, it does not.
I have checked the following possible error sources:
- LED id=645 is not used anywhere else
- there are no influences from other LED hw_id=609 colors
- Key=45 Chn=6 is not used anywhere else
- Terminal "check id LED:645" -> value=127
- tested an other Button hw_id to set bank
What else could cause the problem?
Thanks for any advice!
Best regards
Marxon
Edited by Marxon
Did you try the "debug on" mode? It reports the function calls during an event is processed.
It could help you to understand, under which circumstances the LED status is changed.
It looks like there is a endless loop created somewhere in the .ngc
But i can not find its source :no:
[117026.465] set debug on
[117026.438] Debug mode turned on
[117026.586] MBNG_DIN_NotifyToggle(29, 0)
[117026.589] [EVENT] id=BUTTON:29 hw_id=BUTTON:29 bank=0 fwd_id=DISABLED:0 type=Meta value=71 label=
[117026.589] MBNG_DOUT_NotifyReceivedValue(2000, 0)
[117026.589] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 1000, 0)
[117026.590] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 1400, 0)
[117026.591] MBNG_DIN_NotifyReceivedValue(25, 0)
[117026.593] MBNG_DIN_NotifyReceivedValue(24, 0)
[117026.599] MBNG_DIN_NotifyReceivedValue(23, 0)
[117026.609] MBNG_DIN_NotifyReceivedValue(26, 0)
[117026.617] MBNG_DIN_NotifyReceivedValue(28, 0)
[117026.624] MBNG_DIN_NotifyReceivedValue(21, 0)
[117026.625] MBNG_DIN_NotifyReceivedValue(29, 71)
[117026.626] MBNG_DIN_NotifyReceivedValue(18, 0)
[117026.627] MBNG_DIN_NotifyReceivedValue(74, 0)
[117026.631] MBNG_DIN_NotifyReceivedValue(71, 0)
[117026.631] MBNG_DIN_NotifyReceivedValue(70, 0)
[117026.631] MBNG_DIN_NotifyReceivedValue(75, 0)
[117026.634] MBNG_DIN_NotifyReceivedValue(69, 0)
[117026.634] MBNG_DIN_NotifyReceivedValue(77, 0)
[117026.634] MBNG_DIN_NotifyReceivedValue(68, 0)
[117026.637] MBNG_DIN_NotifyReceivedValue(78, 0)
[117026.638] MBNG_DIN_NotifyReceivedValue(67, 0)
[117026.638] MBNG_DIN_NotifyReceivedValue(33, 0)
[117026.638] MBNG_DIN_NotifyReceivedValue(34, 0)
[117026.638] MBNG_DIN_NotifyReceivedValue(35, 0)
[117026.639] MBNG_DIN_NotifyReceivedValue(38, 0)
[117026.639] MBNG_DIN_NotifyReceivedValue(39, 0)
[117026.639] MBNG_DIN_NotifyReceivedValue(37, 0)
[117026.641] MBNG_DIN_NotifyReceivedValue(40, 0)
[117026.641] MBNG_ENC_NotifyReceivedValue(3, 0)
[117026.641] MBNG_ENC_NotifyReceivedValue(4, 0)
[117026.641] MBNG_DIN_NotifyReceivedValue(45, 0)
[117026.642] MBNG_DIN_NotifyReceivedValue(46, 0)
[117026.643] MBNG_DIN_NotifyReceivedValue(47, 0)
[117026.643] MBNG_DIN_NotifyReceivedValue(46, 0)
[117026.643] MBNG_DIN_NotifyReceivedValue(49, 0)
[117026.643] MBNG_DIN_NotifyReceivedValue(50, 0)
[117026.644] MBNG_DIN_NotifyReceivedValue(51, 0)
[117026.644] MBNG_DIN_NotifyReceivedValue(52, 0)
[117026.644] MBNG_DIN_NotifyReceivedValue(54, 0)
[117026.644] MBNG_DIN_NotifyReceivedValue(55, 0)
[117026.647] MBNG_DIN_NotifyReceivedValue(53, 0)
[117026.648] MBNG_DIN_NotifyReceivedValue(56, 0)
[117026.649] MBNG_ENC_NotifyReceivedValue(5, 0)
[117026.649] MBNG_ENC_NotifyReceivedValue(6, 0)
[117026.650] MBNG_DIN_NotifyReceivedValue(61, 0)
[117026.650] MBNG_DIN_NotifyReceivedValue(62, 0)
[117026.651] MBNG_DIN_NotifyReceivedValue(48, 0)
[117026.651] MBNG_ENC_NotifyReceivedValue(7, 0)
[117026.652] MBNG_ENC_NotifyReceivedValue(7, 0)
[117026.652] MBNG_ENC_NotifyReceivedValue(8, 0)
[117026.653] MBNG_ENC_NotifyReceivedValue(8, 0)
[117026.656] MBNG_ENC_NotifyReceivedValue(8, 0)
[117026.658] MBNG_ENC_NotifyReceivedValue(8, 0)
[117026.658] MBNG_ENC_NotifyReceivedValue(9, 0)
[117026.659] MBNG_ENC_NotifyReceivedValue(9, 0)
[117026.660] MBNG_ENC_NotifyReceivedValue(9, 0)
[117026.660] MBNG_ENC_NotifyReceivedValue(10, 0)
[117026.661] MBNG_ENC_NotifyReceivedValue(10, 0)
[117026.664] MBNG_ENC_NotifyReceivedValue(10, 0)
[117026.665] MBNG_ENC_NotifyReceivedValue(10, 0)
[117026.665] MBNG_ENC_NotifyReceivedValue(11, 1)
[117026.665] MBNG_DIN_NotifyReceivedValue(91, 0)
[117026.666] MBNG_DIN_NotifyReceivedValue(92, 0)
[117026.666] MBNG_DIN_NotifyReceivedValue(95, 0)
[117026.666] MBNG_DIN_NotifyReceivedValue(94, 0)
[117026.673] MBNG_DIN_NotifyReceivedValue(96, 0)
[117026.674] MBNG_DIN_NotifyReceivedValue(105, 0)
[117026.674] MBNG_DIN_NotifyReceivedValue(106, 0)
[117026.674] MBNG_DIN_NotifyReceivedValue(107, 0)
[117026.675] MBNG_DIN_NotifyReceivedValue(108, 0)
[117026.675] MBNG_DIN_NotifyReceivedValue(109, 0)
[117026.676] MBNG_DIN_NotifyReceivedValue(110, 0)
[117026.677] MBNG_DIN_NotifyReceivedValue(110, 0)
[117026.678] MBNG_DIN_NotifyReceivedValue(110, 0)
[117026.681] MBNG_DIN_NotifyReceivedValue(110, 0)
[117026.682] MBNG_DIN_NotifyReceivedValue(110, 0)
[117026.682] MBNG_ENC_NotifyReceivedValue(12, 0)
[117026.683] MBNG_ENC_NotifyReceivedValue(12, 0)
[117026.683] MBNG_DIN_NotifyReceivedValue(97, 0)
[117026.683] MBNG_DIN_NotifyReceivedValue(98, 0)
[117026.684] MBNG_DIN_NotifyReceivedValue(99, 0)
[117026.684] MBNG_DIN_NotifyReceivedValue(104, 0)
[117026.684] MBNG_DIN_NotifyReceivedValue(100, 0)
[117026.685] MBNG_DIN_NotifyReceivedValue(103, 0)
[117026.686] MBNG_DIN_NotifyReceivedValue(103, 0)
[117026.686] MBNG_ENC_NotifyReceivedValue(13, 0)
[117026.687] MBNG_ENC_NotifyReceivedValue(13, 0)
[117026.688] MBNG_ENC_NotifyReceivedValue(13, 0)
[117026.688] MBNG_DIN_NotifyReceivedValue(1040, 0)
[117026.688] MBNG_DIN_NotifyReceivedValue(1048, 0)
[117026.688] MBNG_DIN_NotifyReceivedValue(1033, 0)
[117026.688] MBNG_DIN_NotifyReceivedValue(1041, 0)
[117026.689] MBNG_DIN_NotifyReceivedValue(1034, 0)
[117026.689] MBNG_DIN_NotifyReceivedValue(1042, 0)
[117026.689] MBNG_DIN_NotifyReceivedValue(1035, 0)
[117026.689] MBNG_DIN_NotifyReceivedValue(1043, 0)
[117026.689] MBNG_ENC_NotifyReceivedValue(1001, 0)
[117026.690] MBNG_ENC_NotifyReceivedValue(1002, 0)
[117026.690] MBNG_ENC_NotifyReceivedValue(1003, 0)
[117026.690] MBNG_ENC_NotifyReceivedValue(1004, 0)
[117026.691] MBNG_ENC_NotifyReceivedValue(1005, 0)
[117026.691] MBNG_ENC_NotifyReceivedValue(1006, 0)
[117026.691] MBNG_ENC_NotifyReceivedValue(1007, 0)
[117026.692] MBNG_ENC_NotifyReceivedValue(1008, 0)
[117026.692] MBNG_ENC_NotifyReceivedValue(1009, 0)
[117026.692] MBNG_ENC_NotifyReceivedValue(1010, 0)
[117026.692] MBNG_ENC_NotifyReceivedValue(1011, 0)
[117026.692] MBNG_ENC_NotifyReceivedValue(1012, 0)
[117026.693] MBNG_ENC_NotifyReceivedValue(1013, 0)
[117026.693] MBNG_ENC_NotifyReceivedValue(1014, 0)
[117026.693] MBNG_ENC_NotifyReceivedValue(1015, 0)
[117026.693] MBNG_ENC_NotifyReceivedValue(1016, 0)
[117026.694] MBNG_ENC_NotifyReceivedValue(1017, 0)
[117026.694] MBNG_ENC_NotifyReceivedValue(1018, 0)
[117026.694] MBNG_ENC_NotifyReceivedValue(1019, 0)
[117026.694] MBNG_ENC_NotifyReceivedValue(1020, 0)
[117026.697] MBNG_ENC_NotifyReceivedValue(1021, 0)
[117026.697] MBNG_ENC_NotifyReceivedValue(1022, 0)
[117026.697] MBNG_ENC_NotifyReceivedValue(1023, 0)
[117026.698] MBNG_ENC_NotifyReceivedValue(1024, 0)
[117026.698] MBNG_ENC_NotifyReceivedValue(1025, 0)
[117026.698] MBNG_ENC_NotifyReceivedValue(1026, 0)
[117026.698] MBNG_ENC_NotifyReceivedValue(1027, 0)
[117026.699] MBNG_ENC_NotifyReceivedValue(1028, 0)
[117026.699] MBNG_ENC_NotifyReceivedValue(1029, 0)
[117026.699] MBNG_ENC_NotifyReceivedValue(1030, 0)
[117026.700] MBNG_ENC_NotifyReceivedValue(1031, 0)
[117026.700] MBNG_ENC_NotifyReceivedValue(1032, 0)
[117026.700] MBNG_ENC_NotifyReceivedValue(1033, 0)
[117026.700] MBNG_ENC_NotifyReceivedValue(1034, 0)
[117026.701] MBNG_ENC_NotifyReceivedValue(1035, 0)
[117026.701] MBNG_ENC_NotifyReceivedValue(1036, 0)
[117026.701] MBNG_ENC_NotifyReceivedValue(1037, 0)
[117026.701] MBNG_ENC_NotifyReceivedValue(1038, 0)
[117026.702] MBNG_ENC_NotifyReceivedValue(1039, 0)
[117026.702] MBNG_ENC_NotifyReceivedValue(1040, 0)
[117026.702] MBNG_ENC_NotifyReceivedValue(1041, 0)
[117026.702] MBNG_ENC_NotifyReceivedValue(1042, 0)
[117026.703] MBNG_ENC_NotifyReceivedValue(1043, 0)
[117026.703] MBNG_ENC_NotifyReceivedValue(1044, 0)
[117026.703] MBNG_ENC_NotifyReceivedValue(1045, 0)
[117026.704] MBNG_ENC_NotifyReceivedValue(1046, 0)
[117026.704] MBNG_ENC_NotifyReceivedValue(1047, 0)
[117026.704] MBNG_ENC_NotifyReceivedValue(1048, 0)
[117026.704] MBNG_DIN_NotifyReceivedValue(1036, 0)
[117026.704] MBNG_DIN_NotifyReceivedValue(1044, 0)
[117026.705] MBNG_DIN_NotifyReceivedValue(1037, 0)
[117026.705] MBNG_DIN_NotifyReceivedValue(1045, 0)
[117026.705] MBNG_DIN_NotifyReceivedValue(1038, 0)
[117026.705] MBNG_DIN_NotifyReceivedValue(1046, 0)
[117026.706] MBNG_DIN_NotifyReceivedValue(1039, 0)
[117026.706] MBNG_DIN_NotifyReceivedValue(1047, 0)
[117026.706] MBNG_DIN_NotifyReceivedValue(1004, 0)
[117026.706] MBNG_DIN_NotifyReceivedValue(1005, 0)
[117026.706] MBNG_DIN_NotifyReceivedValue(1006, 0)
[117026.707] MBNG_DIN_NotifyReceivedValue(1007, 0)
[117026.707] MBNG_DIN_NotifyReceivedValue(1012, 0)
[117026.707] MBNG_DIN_NotifyReceivedValue(1013, 0)
[117026.707] MBNG_DIN_NotifyReceivedValue(1014, 0)
[117026.708] MBNG_DIN_NotifyReceivedValue(1015, 0)
[117026.708] MBNG_ENC_NotifyReceivedValue(1133, 0)
[117026.717] MBNG_ENC_NotifyReceivedValue(1134, 0)
[117026.717] MBNG_ENC_NotifyReceivedValue(1135, 0)
[117026.717] MBNG_ENC_NotifyReceivedValue(1136, 0)
[117026.717] MBNG_ENC_NotifyReceivedValue(1137, 0)
[117026.717] MBNG_ENC_NotifyReceivedValue(1138, 0)
[117026.717] MBNG_ENC_NotifyReceivedValue(1139, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1140, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1141, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1142, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1143, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1144, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1145, 0)
[117026.718] MBNG_ENC_NotifyReceivedValue(1146, 0)
[117026.719] MBNG_ENC_NotifyReceivedValue(1147, 0)
[117026.719] MBNG_ENC_NotifyReceivedValue(1148, 0)
[117026.719] MBNG_DIN_NotifyReceivedValue(2003, 0)
[117026.719] MBNG_DIN_NotifyReceivedValue(2004, 0)
[117026.719] MBNG_DIN_NotifyReceivedValue(2005, 0)
[117026.719] MBNG_DIN_NotifyReceivedValue(2006, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2007, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2011, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2012, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2013, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2014, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2015, 0)
[117026.720] MBNG_DIN_NotifyReceivedValue(2019, 0)
[117026.721] MBNG_DIN_NotifyReceivedValue(2020, 0)
[117026.721] MBNG_DIN_NotifyReceivedValue(2021, 0)
[117026.721] MBNG_DIN_NotifyReceivedValue(2022, 0)
[117026.721] MBNG_DIN_NotifyReceivedValue(2023, 0)
[117026.721] MBNG_DIN_NotifyReceivedValue(2027, 0)
[117026.722] MBNG_DIN_NotifyReceivedValue(2028, 0)
[117026.722] MBNG_DIN_NotifyReceivedValue(2029, 0)
[117026.722] MBNG_DIN_NotifyReceivedValue(2030, 0)
[117026.722] MBNG_DIN_NotifyReceivedValue(2031, 0)
[117026.722] MBNG_AINSER_NotifyReceivedValue(1, 0)
[117026.722] MBNG_AINSER_NotifyReceivedValue(2, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(3, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(4, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(5, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(6, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(7, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(9, 0)
[117026.723] MBNG_AINSER_NotifyReceivedValue(10, 0)
[117026.724] MBNG_AINSER_NotifyReceivedValue(11, 0)
[117026.724] MBNG_AINSER_NotifyReceivedValue(12, 0)
[117026.724] MBNG_AINSER_NotifyReceivedValue(13, 0)
[117026.724] MBNG_AINSER_NotifyReceivedValue(14, 0)
[117026.724] MBNG_AINSER_NotifyReceivedValue(17, 0)
[117026.724] MBNG_AINSER_NotifyReceivedValue(18, 0)
[117026.725] MBNG_AINSER_NotifyReceivedValue(19, 0)
[117026.725] MBNG_AINSER_NotifyReceivedValue(20, 0)
[117026.725] MBNG_AINSER_NotifyReceivedValue(21, 0)
[117026.725] MBNG_AINSER_NotifyReceivedValue(22, 0)
[117026.725] MBNG_AINSER_NotifyReceivedValue(23, 0)
[117026.725] MBNG_AINSER_NotifyReceivedValue(25, 0)
[117026.726] MBNG_AINSER_NotifyReceivedValue(26, 0)
[117026.726] MBNG_AINSER_NotifyReceivedValue(27, 0)
[117026.726] MBNG_AINSER_NotifyReceivedValue(28, 0)
[117026.728] MBNG_AINSER_NotifyReceivedValue(29, 0)
[117026.728] MBNG_AINSER_NotifyReceivedValue(30, 0)
[117026.728] MBNG_MATRIX_DOUT_NotifyReceivedValue(1, 1, 0)
[117026.728] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 1, 0)
[117026.729] MBNG_MATRIX_DOUT_NotifyReceivedValue(17, 1, 0)
[117026.729] MBNG_MATRIX_DOUT_NotifyReceivedValue(18, 1, 0)
[117026.729] MBNG_MATRIX_DOUT_NotifyReceivedValue(3, 1, 0)
[117026.729] MBNG_MATRIX_DOUT_NotifyReceivedValue(4, 1, 0)
[117026.729] MBNG_MATRIX_DOUT_NotifyReceivedValue(19, 1, 0)
[117026.730] MBNG_MATRIX_DOUT_NotifyReceivedValue(20, 1, 0)
[117026.730] MBNG_MATRIX_DOUT_NotifyReceivedValue(33, 1, 0)
[117026.730] MBNG_MATRIX_DOUT_NotifyReceivedValue(34, 1, 0)
[117026.730] MBNG_MATRIX_DOUT_NotifyReceivedValue(49, 1, 0)
[117026.730] MBNG_MATRIX_DOUT_NotifyReceivedValue(50, 1, 0)
[117026.731] MBNG_MATRIX_DOUT_NotifyReceivedValue(35, 1, 0)
[117026.731] MBNG_MATRIX_DOUT_NotifyReceivedValue(36, 1, 0)
[117026.731] MBNG_MATRIX_DOUT_NotifyReceivedValue(51, 1, 0)
[117026.731] MBNG_MATRIX_DOUT_NotifyReceivedValue(52, 1, 0)
[117026.732] MBNG_DOUT_NotifyReceivedValue(1001, 0)
[117026.732] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 1, 0)
[117026.732] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 401, 0)
[117026.732] MBNG_DOUT_NotifyReceivedValue(1002, 127)
[117026.733] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 2, 127)
[117026.733] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 402, 127)
[117026.733] MBNG_DOUT_NotifyReceivedValue(1003, 0)
[117026.733] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 3, 0)
[117026.734] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 403, 0)
[117026.734] MBNG_DOUT_NotifyReceivedValue(1004, 0)
[117026.734] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 4, 0)
[117026.734] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 404, 0)
[117026.734] MBNG_DOUT_NotifyReceivedValue(1009, 127)
[117026.734] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 9, 127)
[117026.735] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 409, 127)
[117026.735] MBNG_DOUT_NotifyReceivedValue(1010, 0)
[117026.735] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 10, 0)
[117026.735] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 410, 0)
[117026.735] MBNG_DOUT_NotifyReceivedValue(1011, 0)
[117026.735] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 11, 0)
[117026.736] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 411, 0)
[117026.736] MBNG_DOUT_NotifyReceivedValue(1012, 127)
[117026.736] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 12, 127)
[117026.736] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 412, 127)
[117026.736] MBNG_DOUT_NotifyReceivedValue(1001, 0)
[117026.736] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 1, 0)
[117026.737] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 401, 0)
[117026.737] MBNG_DOUT_NotifyReceivedValue(1002, 0)
[117026.737] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 2, 0)
[117026.737] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 402, 0)
[117026.737] MBNG_DOUT_NotifyReceivedValue(1003, 0)
[117026.737] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 3, 0)
[117026.738] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 403, 0)
[117026.738] MBNG_DOUT_NotifyReceivedValue(1004, 0)
[117026.738] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 4, 0)
[117026.738] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 404, 0)
[117026.738] MBNG_DOUT_NotifyReceivedValue(1009, 0)
[117026.739] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 9, 0)
[117026.739] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 409, 0)
[117026.739] MBNG_DOUT_NotifyReceivedValue(1010, 0)
[117026.739] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 10, 0)
[117026.739] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 410, 0)
[117026.740] MBNG_DOUT_NotifyReceivedValue(1011, 0)
[117026.740] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 11, 0)
[117026.740] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 411, 0)
[117026.740] MBNG_DOUT_NotifyReceivedValue(1012, 0)
[117026.740] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 12, 0)
[117026.740] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 412, 0)
[117026.741] MBNG_DOUT_NotifyReceivedValue(1017, 0)
[117026.741] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 17, 0)
[117026.741] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 417, 0)
[117026.741] MBNG_DOUT_NotifyReceivedValue(1018, 0)
[117026.741] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 18, 0)
[117026.741] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 418, 0)
[117026.742] MBNG_DOUT_NotifyReceivedValue(1019, 0)
[117026.742] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 19, 0)
[117026.742] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 419, 0)
[117026.742] MBNG_DOUT_NotifyReceivedValue(1020, 0)
[117026.742] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 20, 0)
[117026.742] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 420, 0)
[117026.743] MBNG_DOUT_NotifyReceivedValue(1025, 0)
[117026.743] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 25, 0)
[117026.743] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 425, 0)
[117026.743] MBNG_DOUT_NotifyReceivedValue(1026, 0)
[117026.743] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 26, 0)
[117026.744] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 426, 0)
[117026.744] MBNG_DOUT_NotifyReceivedValue(1027, 0)
[117026.744] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 27, 0)
[117026.744] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 427, 0)
[117026.744] MBNG_DOUT_NotifyReceivedValue(1028, 0)
[117026.746] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 28, 0)
[117026.746] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117026.746] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117026.747] MBNG_DOUT_NotifyReceivedValue(1017, 0)
[117026.747] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 17, 0)
[117026.747] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 417, 0)
[117026.747] MBNG_DOUT_NotifyReceivedValue(1018, 0)
[117026.747] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 18, 0)
[117026.748] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 418, 0)
[117026.748] MBNG_DOUT_NotifyReceivedValue(1019, 0)
[117026.748] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 19, 0)
[117026.748] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 419, 0)
[117026.748] MBNG_DOUT_NotifyReceivedValue(1020, 0)
[117026.749] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 20, 0)
[117026.749] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 420, 0)
[117026.749] MBNG_DOUT_NotifyReceivedValue(1025, 0)
[117026.749] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 25, 0)
[117026.749] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 425, 0)
[117026.749] MBNG_DOUT_NotifyReceivedValue(1026, 0)
[117026.750] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 26, 0)
[117026.750] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 426, 0)
[117026.750] MBNG_DOUT_NotifyReceivedValue(1027, 0)
[117026.750] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 27, 0)
[117026.750] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 427, 0)
[117026.751] MBNG_DOUT_NotifyReceivedValue(1028, 0)
[117026.751] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 28, 0)
[117026.751] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 428, 0)
[117026.751] MBNG_DOUT_NotifyReceivedValue(1017, 0)
[117026.751] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 17, 0)
[117026.752] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 417, 0)
[117026.752] MBNG_DOUT_NotifyReceivedValue(1018, 0)
[117026.752] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 18, 0)
[117026.753] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 418, 0)
[117026.753] MBNG_DOUT_NotifyReceivedValue(1019, 0)
[117026.753] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 19, 0)
[117026.753] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 419, 0)
[117026.753] MBNG_DOUT_NotifyReceivedValue(1020, 0)
[117026.754] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 20, 0)
[117026.754] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 420, 0)
[117026.754] MBNG_DOUT_NotifyReceivedValue(1025, 0)
[117026.754] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 25, 0)
[117026.754] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 425, 0)
[117026.755] MBNG_DOUT_NotifyReceivedValue(1026, 0)
[117026.755] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 26, 0)
[117026.755] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 426, 0)
[117026.755] MBNG_DOUT_NotifyReceivedValue(1027, 0)
[117026.755] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 27, 0)
[117026.755] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 427, 0)
[117026.756] MBNG_DOUT_NotifyReceivedValue(1028, 0)
[117026.756] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 28, 0)
[117026.756] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 428, 0)
[117026.756] MBNG_DOUT_NotifyReceivedValue(1005, 0)
[117026.756] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 5, 0)
[117026.756] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 405, 0)
[117026.757] MBNG_DOUT_NotifyReceivedValue(1006, 0)
[117026.757] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 6, 0)
[117026.757] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 406, 0)
[117026.757] MBNG_DOUT_NotifyReceivedValue(1007, 0)
[117026.757] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 7, 0)
[117026.757] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 407, 0)
[117026.758] MBNG_DOUT_NotifyReceivedValue(1008, 0)
[117026.766] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 8, 0)
[117026.766] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 408, 0)
[117026.767] MBNG_DOUT_NotifyReceivedValue(1013, 0)
[117026.767] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 13, 0)
[117026.767] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 413, 0)
[117026.767] MBNG_DOUT_NotifyReceivedValue(1014, 0)
[117026.767] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 14, 0)
[117026.768] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 414, 0)
[117026.768] MBNG_DOUT_NotifyReceivedValue(1015, 0)
[117026.768] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 15, 0)
[117026.768] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 415, 0)
[117026.768] MBNG_DOUT_NotifyReceivedValue(1016, 0)
[117026.769] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 16, 0)
[117026.769] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 416, 0)
[117026.770] MBNG_DOUT_NotifyReceivedValue(1005, 0)
[117026.770] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 5, 0)
[117026.770] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 405, 0)
[117026.770] MBNG_DOUT_NotifyReceivedValue(1006, 0)
[117026.770] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 6, 0)
[117026.770] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 406, 0)
[117026.771] MBNG_DOUT_NotifyReceivedValue(1007, 0)
[117026.771] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 7, 0)
[117026.771] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 407, 0)
[117026.771] MBNG_DOUT_NotifyReceivedValue(1008, 0)
[117026.771] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 8, 0)
[117026.771] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 408, 0)
[117026.772] MBNG_DOUT_NotifyReceivedValue(1013, 0)
[117026.772] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 13, 0)
[117026.772] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 413, 0)
[117026.772] MBNG_DOUT_NotifyReceivedValue(1014, 0)
[117026.772] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 14, 0)
[117026.772] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 414, 0)
[117026.773] MBNG_DOUT_NotifyReceivedValue(1015, 0)
[117026.773] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 15, 0)
[117026.773] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 415, 0)
[117026.773] MBNG_DOUT_NotifyReceivedValue(1016, 0)
[117026.773] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 16, 0)
[117026.773] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 416, 0)
[117026.774] MBNG_DOUT_NotifyReceivedValue(1021, 0)
[117026.774] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 21, 0)
[117026.774] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 421, 0)
[117026.774] MBNG_DOUT_NotifyReceivedValue(1022, 0)
[117026.774] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 22, 0)
[117026.775] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 422, 0)
[117026.775] MBNG_DOUT_NotifyReceivedValue(1023, 0)
[117026.775] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 23, 0)
[117026.775] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 423, 0)
[117026.775] MBNG_DOUT_NotifyReceivedValue(1024, 0)
[117026.776] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 24, 0)
[117026.776] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 424, 0)
[117026.776] MBNG_DOUT_NotifyReceivedValue(1029, 0)
[117026.776] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 29, 0)
[117026.776] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 429, 0)
[117026.776] MBNG_DOUT_NotifyReceivedValue(1030, 0)
[117026.777] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 30, 0)
[117026.777] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 430, 0)
[117026.777] MBNG_DOUT_NotifyReceivedValue(1031, 0)
[117026.777] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 31, 0)
[117026.777] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 431, 0)
[117026.777] MBNG_DOUT_NotifyReceivedValue(1034, 0)
[117026.778] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 34, 0)
[117026.779] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 434, 0)
[117026.780] MBNG_DOUT_NotifyReceivedValue(1021, 0)
[117026.780] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 21, 0)
[117026.780] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 421, 0)
[117026.780] MBNG_DOUT_NotifyReceivedValue(1022, 0)
[117026.780] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 22, 0)
[117026.781] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 422, 0)
[117026.781] MBNG_DOUT_NotifyReceivedValue(1023, 0)
[117026.781] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 23, 0)
[117026.781] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 423, 0)
[117026.781] MBNG_DOUT_NotifyReceivedValue(1024, 0)
[117026.782] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 24, 0)
[117026.782] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 424, 0)
[117026.782] MBNG_DOUT_NotifyReceivedValue(1029, 0)
[117026.783] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 29, 0)
[117026.783] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 429, 0)
[117026.783] MBNG_DOUT_NotifyReceivedValue(1030, 0)
[117026.783] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 30, 0)
[117026.783] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 430, 0)
[117026.783] MBNG_DOUT_NotifyReceivedValue(1031, 0)
[117026.784] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 31, 0)
[117026.784] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 431, 0)
[117026.784] MBNG_DOUT_NotifyReceivedValue(1032, 0)
[117026.784] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 32, 0)
[117026.784] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 432, 0)
[117026.785] MBNG_DOUT_NotifyReceivedValue(1021, 0)
[117026.785] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 21, 0)
[117026.785] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 421, 0)
[117026.785] MBNG_DOUT_NotifyReceivedValue(1022, 0)
[117026.785] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 22, 0)
[117026.786] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 422, 0)
[117026.786] MBNG_DOUT_NotifyReceivedValue(1023, 0)
[117026.786] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 23, 0)
[117026.786] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 423, 0)
[117026.786] MBNG_DOUT_NotifyReceivedValue(1024, 0)
[117026.786] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 24, 0)
[117026.787] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 424, 0)
[117026.787] MBNG_DOUT_NotifyReceivedValue(1029, 0)
[117026.787] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 29, 0)
[117026.787] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 429, 0)
[117026.787] MBNG_DOUT_NotifyReceivedValue(1030, 0)
[117026.787] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 30, 0)
[117026.788] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 430, 0)
[117026.788] MBNG_DOUT_NotifyReceivedValue(1031, 0)
[117026.788] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 31, 0)
[117026.788] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 431, 0)
[117026.788] MBNG_DOUT_NotifyReceivedValue(1032, 0)
[117026.789] MBNG_MATRIX_DOUT_NotifyReceivedValue(5, 32, 0)
[117026.789] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 432, 0)
[117026.789] MBNG_MATRIX_DOUT_NotifyReceivedValue(81, 1, 57)
[117026.789] MBNG_MATRIX_DOUT_NotifyReceivedValue(82, 1, 57)
[117026.790] MBNG_MATRIX_DOUT_NotifyReceivedValue(83, 1, 57)
[117026.790] MBNG_MATRIX_DOUT_NotifyReceivedValue(84, 1, 57)
[117026.790] MBNG_MATRIX_DOUT_NotifyReceivedValue(85, 1, 57)
[117026.790] MBNG_MATRIX_DOUT_NotifyReceivedValue(97, 1, 0)
[117026.790] MBNG_MATRIX_DOUT_NotifyReceivedValue(98, 1, 0)
[117026.791] MBNG_MATRIX_DOUT_NotifyReceivedValue(99, 1, 0)
[117026.791] MBNG_MATRIX_DOUT_NotifyReceivedValue(100, 1, 0)
[117026.791] MBNG_DOUT_NotifyReceivedValue(609, 0)
[117026.791] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 9, 0)
[117026.791] MBNG_DOUT_NotifyReceivedValue(610, 0)
[117026.791] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 10, 0)
[117026.792] MBNG_DOUT_NotifyReceivedValue(611, 0)
[117026.792] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 11, 0)
[117026.792] MBNG_DOUT_NotifyReceivedValue(612, 0)
[117026.792] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 12, 0)
[117026.792] MBNG_DOUT_NotifyReceivedValue(613, 0)
[117026.792] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 13, 0)
[117026.793] MBNG_DOUT_NotifyReceivedValue(614, 0)
[117026.793] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 14, 0)
[117026.793] MBNG_DOUT_NotifyReceivedValue(615, 0)
[117026.793] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 15, 0)
[117026.793] MBNG_DOUT_NotifyReceivedValue(616, 0)
[117026.793] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 16, 0)
[117026.794] MBNG_DOUT_NotifyReceivedValue(601, 0)
[117026.794] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 1, 0)
[117026.794] MBNG_DOUT_NotifyReceivedValue(602, 0)
[117026.806] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 2, 0)
[117026.806] MBNG_DOUT_NotifyReceivedValue(603, 0)
[117026.807] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 3, 0)
[117026.807] MBNG_DOUT_NotifyReceivedValue(604, 0)
[117026.807] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 4, 0)
[117026.807] MBNG_DOUT_NotifyReceivedValue(605, 0)
[117026.807] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 5, 0)
[117026.808] MBNG_DOUT_NotifyReceivedValue(606, 0)
[117026.808] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 6, 0)
[117026.815] MBNG_DOUT_NotifyReceivedValue(607, 0)
[117026.816] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 7, 0)
[117026.816] MBNG_DOUT_NotifyReceivedValue(608, 0)
[117026.816] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 8, 0)
[117026.816] MBNG_DOUT_NotifyReceivedValue(615, 0)
[117026.816] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 15, 0)
[117026.817] MBNG_DOUT_NotifyReceivedValue(614, 0)
[117026.817] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 14, 0)
[117026.817] MBNG_DOUT_NotifyReceivedValue(613, 0)
[117026.817] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 13, 0)
[117026.817] MBNG_DOUT_NotifyReceivedValue(612, 0)
[117026.818] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 12, 0)
[117026.818] MBNG_DOUT_NotifyReceivedValue(611, 0)
[117026.818] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 11, 0)
[117026.818] MBNG_DOUT_NotifyReceivedValue(610, 127)
[117026.818] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 10, 127)
[117026.818] MBNG_DOUT_NotifyReceivedValue(609, 0)
[117026.819] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 9, 0)
[117026.819] MBNG_DOUT_NotifyReceivedValue(608, 0)
[117026.819] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 8, 0)
[117026.819] MBNG_DOUT_NotifyReceivedValue(607, 0)
[117026.819] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 7, 0)
[117026.819] MBNG_DOUT_NotifyReceivedValue(606, 0)
[117026.820] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 6, 0)
[117026.820] MBNG_DOUT_NotifyReceivedValue(605, 0)
[117026.820] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 5, 0)
[117026.820] MBNG_DOUT_NotifyReceivedValue(604, 0)
[117026.820] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 4, 0)
[117026.820] MBNG_DOUT_NotifyReceivedValue(603, 0)
[117026.821] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 3, 0)
[117026.821] MBNG_DOUT_NotifyReceivedValue(602, 0)
[117026.821] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 2, 0)
[117026.821] MBNG_DOUT_NotifyReceivedValue(601, 0)
[117026.821] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 1, 0)
[117026.822] MBNG_DOUT_NotifyReceivedValue(616, 0)
[117026.822] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 16, 0)
[117026.822] MBNG_DOUT_NotifyReceivedValue(604, 0)
[117026.822] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 4, 0)
[117026.822] MBNG_DOUT_NotifyReceivedValue(605, 0)
[117026.823] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 5, 0)
[117026.823] MBNG_DOUT_NotifyReceivedValue(606, 0)
[117026.823] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 6, 0)
[117026.823] MBNG_DOUT_NotifyReceivedValue(607, 0)
[117026.824] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 7, 0)
[117026.824] MBNG_DOUT_NotifyReceivedValue(608, 0)
[117026.824] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 8, 0)
[117026.824] MBNG_DOUT_NotifyReceivedValue(612, 0)
[117026.824] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 12, 0)
[117026.824] MBNG_DOUT_NotifyReceivedValue(613, 0)
[117026.825] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 13, 0)
[117026.825] MBNG_DOUT_NotifyReceivedValue(614, 0)
[117026.825] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 14, 0)
[117026.825] MBNG_DOUT_NotifyReceivedValue(615, 0)
[117026.825] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 15, 0)
[117026.825] MBNG_DOUT_NotifyReceivedValue(616, 0)
[117026.826] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 16, 0)
[117026.826] MBNG_DOUT_NotifyReceivedValue(620, 0)
[117026.826] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 20, 0)
[117026.826] MBNG_DOUT_NotifyReceivedValue(621, 0)
[117026.826] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 21, 0)
[117026.826] MBNG_DOUT_NotifyReceivedValue(622, 0)
[117026.827] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 22, 0)
[117026.827] MBNG_DOUT_NotifyReceivedValue(623, 0)
[117026.827] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 23, 0)
[117026.827] MBNG_DOUT_NotifyReceivedValue(624, 0)
[117026.827] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 24, 0)
[117026.827] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117026.828] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117026.830] MBNG_DOUT_NotifyReceivedValue(629, 0)
[117026.831] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 29, 0)
[117026.831] MBNG_DOUT_NotifyReceivedValue(630, 0)
[117026.831] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 30, 0)
[117026.832] MBNG_DOUT_NotifyReceivedValue(631, 0)
[117026.832] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 31, 0)
[117026.832] MBNG_DOUT_NotifyReceivedValue(632, 0)
[117026.832] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 32, 0)
[117026.832] MBNG_DOUT_NotifyReceivedValue(609, 0)
[117026.832] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 9, 0)
[117026.833] MBNG_DOUT_NotifyReceivedValue(610, 0)
[117026.833] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 10, 0)
[117026.833] MBNG_DOUT_NotifyReceivedValue(611, 0)
[117026.833] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 11, 0)
[117026.833] MBNG_DOUT_NotifyReceivedValue(601, 0)
[117026.834] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 1, 0)
[117026.834] MBNG_DOUT_NotifyReceivedValue(602, 0)
[117026.834] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 2, 0)
[117026.834] MBNG_DOUT_NotifyReceivedValue(603, 0)
[117026.834] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 3, 0)
[117026.834] MBNG_DOUT_NotifyReceivedValue(619, 0)
[117026.835] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 19, 0)
[117026.835] MBNG_DOUT_NotifyReceivedValue(620, 0)
[117026.835] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 20, 0)
[117026.835] MBNG_DOUT_NotifyReceivedValue(621, 0)
[117026.835] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 21, 0)
[117026.835] MBNG_DOUT_NotifyReceivedValue(622, 0)
[117026.836] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 22, 0)
[117026.836] MBNG_DOUT_NotifyReceivedValue(623, 0)
[117026.836] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 23, 0)
[117026.836] MBNG_DOUT_NotifyReceivedValue(624, 0)
[117026.836] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 24, 0)
[117026.837] MBNG_DOUT_NotifyReceivedValue(627, 0)
[117026.837] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 27, 0)
[117026.837] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117026.837] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117026.837] MBNG_DOUT_NotifyReceivedValue(629, 0)
[117026.837] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 29, 0)
[117026.838] MBNG_DOUT_NotifyReceivedValue(630, 0)
[117026.838] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 30, 0)
[117026.838] MBNG_DOUT_NotifyReceivedValue(631, 0)
[117026.838] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 31, 0)
[117026.838] MBNG_DOUT_NotifyReceivedValue(632, 127)
[117026.838] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 32, 127)
[117026.839] MBNG_DIN_NotifyToggle(29, 1)
[117026.839] [EVENT] id=BUTTON:29 hw_id=BUTTON:29 bank=0 fwd_id=DISABLED:0 type=Meta value=71 label=
[117026.840] [EVENT] id=BUTTON:29 hw_id=BUTTON:29 bank=0 fwd_id=DISABLED:0 type=Meta value=71 label=
[117026.840] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117026.840] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117027.034] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117027.034] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117027.158] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117027.158] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117027.308] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117027.309] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117027.464] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117027.464] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117027.614] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117027.614] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117027.764] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117027.764] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117027.912] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117027.912] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117028.062] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117028.062] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117028.090] MBNG_MATRIX_DOUT_NotifyReceivedValue(81, 1, 58)
[117028.090] MBNG_MATRIX_DOUT_NotifyReceivedValue(82, 1, 58)
[117028.090] MBNG_MATRIX_DOUT_NotifyReceivedValue(83, 1, 58)
[117028.090] MBNG_MATRIX_DOUT_NotifyReceivedValue(84, 1, 58)
[117028.091] MBNG_MATRIX_DOUT_NotifyReceivedValue(85, 1, 58)
[117028.214] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117028.214] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117028.363] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117028.363] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117028.515] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117028.515] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117028.665] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117028.665] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117028.814] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117028.815] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117028.967] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117028.967] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117029.116] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117029.117] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117029.269] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117029.269] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117029.419] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117029.419] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117029.572] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117029.572] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117029.722] MBNG_DOUT_NotifyReceivedValue(628, 0)
[117029.722] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 0)
[117029.872] MBNG_DOUT_NotifyReceivedValue(628, 127)
[117029.872] MBNG_MATRIX_DOUT_NotifyReceivedValue(8, 28, 127)
[117029.965] set debug off
[117029.939] Debug mode turned off
Somehow I was not able to find the source of my problem.
Therefore i have modified everything without using banks.
It works now, although the drawback of having big latencies on certain actions.
Edited by Marxon
