Sauraen Posted January 13, 2014 Report Posted January 13, 2014 (edited) Hi TK, I thought I'd make this a separate topic. This is for a different DOUT_MATRIX (though same synth) than the one that has swap_rows_columns=1 (it doesn't even have that parameter at all). The first problem I noticed was that mirrored_row=1 didn't seem to do anything. That is, with writes to a bunch of LED ids, and then enabling the parameter, did not change which hardware LEDs lit up. But this is not a serious problem, it just means the assignment numbers will be different. The more serious problem is that the second shift register's worth of LEDs seem not to work (it's 8x16): # LED matrix DOUT_MATRIX n=2 rows=8 inverted_sel=1 sr_dout_sel1=1 \ inverted_row=0 mirrored_row=0 sr_dout_r1=3 sr_dout_r2=4 \ led_emu_id_offset=1001 I made a spreadsheet of how the offset IDs were being assigned to the elements of the matrix: 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1120 1119 1118 1117 1116 1115 1114 1113 1112 1111 1110 1109 1108 1107 1106 1105 1 1104 1103 1102 1101 1100 1099 1098 1097 1096 1095 1094 1093 1092 1091 1090 1089 2 1088 1087 1086 1085 1084 1083 1082 1081 1080 1079 1078 1077 1076 1075 1074 1073 3 1072 1071 1070 1069 1068 1067 1066 1065 1064 1063 1062 1061 1060 1059 1058 1057 4 1056 1055 1054 1053 1052 1051 1050 1049 1048 1047 1046 1045 1044 1043 1042 1041 5 1040 1039 1038 1037 1036 1035 1034 1033 1032 1031 1030 1029 1028 1027 1026 1025 6 1024 1023 1022 1021 1020 1019 1018 1017 1016 1015 1014 1013 1012 1011 1010 1009 7 1008 1007 1006 1005 1004 1003 1002 1001 1000 999 998 997 996 995 994 993 However, only the LEDs on the left shift register (the first 0-7) would light; I extrapolated the numbers for the right side, but couldn't actually confirm them because a statement like EVENT_LED id=1112 [etc.] would do nothing. (I didn't actually try all 64 on the side that were working, just a few here and there to establish the pattern, and at the beginning and end.) Swapping the shift registers in the DOUT_MATRIX definition as follows # LED matrix DOUT_MATRIX n=2 rows=8 inverted_sel=1 sr_dout_sel1=1 \ inverted_row=0 mirrored_row=0 sr_dout_r1=4 sr_dout_r2=3 \ led_emu_id_offset=1001 results in the mapping 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1136 1135 1134 1133 1132 1131 1130 1129 1128 1127 1126 1125 1124 1123 1122 1121 1 1120 1119 1118 1117 1116 1115 1114 1113 1112 1111 1110 1109 1108 1107 1106 1105 2 1104 1103 1102 1101 1100 1099 1098 1097 1096 1095 1094 1093 1092 1091 1090 1089 3 1088 1087 1086 1085 1084 1083 1082 1081 1080 1079 1078 1077 1076 1075 1074 1073 4 1072 1071 1070 1069 1068 1067 1066 1065 1064 1063 1062 1061 1060 1059 1058 1057 5 1056 1055 1054 1053 1052 1051 1050 1049 1048 1047 1046 1045 1044 1043 1042 1041 6 1040 1039 1038 1037 1036 1035 1034 1033 1032 1031 1030 1029 1028 1027 1026 1025 7 1024 1023 1022 1021 1020 1019 1018 1017 1016 1015 1014 1013 1012 1011 1010 1009 with now only the second shift register's worth of LEDs working and the first half not working. That is, the other 64 hardware LEDs now work but the first half don't (it's not a hardware problem). So in both cases only the first-defined shift register will accept LED input, but the mapping is defined across both. In both cases the mapping is not correct either: in the first case it extends below 1001 into the non-working shift register, and in the second case, above 1128 into the non-working shift register. If I can't find anything tonight, I'll try it with code from a new svn checkout just to make sure I didn't screw this up when I was fooling with mbng_matrix.c; but I'm pretty sure that all of the changes I made only executed additional code if swap_rows_columns=1 was active, and left the code untouched otherwise. Besides, I didn't change any code to do with the led_emu_offset_id mapping. Thanks, Sauraen Edited January 13, 2014 by Sauraen Quote
TK. Posted January 13, 2014 Report Posted January 13, 2014 (I won't be able to support you on this topic the next days...) Best Regards, Thorsten. Quote
Sauraen Posted January 14, 2014 Author Report Posted January 14, 2014 I can confirm that both of these problems with led_emu_id_offset--mirrored_row doing nothing and only the first-defined shift register's worth of LEDs working in an 8x16 matrix--exist in the unmodified midibox_ng_v1 (i.e. are actual bugs). I checked out a new copy and tried it again, with the same results. The mapping tables I wrote above also appear to be the same. I'm now going to switch back to the modified copy (so I can have my LED digits working) and see if I can actually fix the bug. Quote
Sauraen Posted January 14, 2014 Author Report Posted January 14, 2014 Bug squashed! Here's the changes: In mbng_matrix.c, MBNG_MATRIX_DOUT_PinSet(): To make mirrored_row work right, right after int row, int column (your line 508), add: //Feature added by Sauraen if(m->flags.mirrored_row) column = (column&0xF8) | (7 - (column&7)); //Only swap lower 8 of column, as per spec To fix the second-shift-register-not-working bug, right after the switch(color) statement (your original line 515), add: //Bug fixed by Sauraen column &= 7; //Above, we picked a different sr if column >= 8, but then we wrote to that sr with column still >= 8 One other bug I discovered while tracing the program flow is in mbng_dout.c, MBNG_DOUT_NotifyReceivedValue(), line 96, I'm pretty sure it should be if( hw_id_ix < (m->led_emu_id_offset + (m->num_rows * row_size)) ) { //Bug? found by Sauraen As it was, m->led_emu_id_offset was being multiplied by m->num_rows, and that looked like it was going to generate a huge number. This might never actually lead to a visible problem, since even though it would pass events with indices too high, at MBNG_MATRIX_DOUT_PinSet() it checks again (at original line 503) to make sure the given pin is in range. But it would have executed a couple hundred extra lines of code per LED event with large index. Quote
TK. Posted January 14, 2014 Report Posted January 14, 2014 Thank you very much, this was a bug^H^Hig help! :thumbsup: I integrated your changes and committed a new version to the SVN server. Best Regards, Thorsten. Quote
Sauraen Posted January 14, 2014 Author Report Posted January 14, 2014 You're welcome! I hope this is only the first of the times my code ends up in the repository, heh heh! Quote
