split Dout Matrix digits/"normal" leds
Hi all,
can i use free dout_sel pins as regular row selection outputs
if less than 8 digits are controlled from my dout matrix?
For example:
to create a 6 digits + 2x8 led matrix?
Best regards
Marxon
unfortunately I can't support this. A SR which is serviced by the matrix code will always be fully allocated, otherwise very time consuming read-modify-write operations on the DOUT array would be required (32 times due to the dim feature!), which affects the overall performance of the application dramatically.
Hi Thorsten,
OK this is no big issue.
I will use a additional SR.
Best regards
Marxon
