alchemist Posted May 7, 2014 Posted May 7, 2014 Hello, I would like create a Control Surface based on a C64 like this: I have a 40x2 display in place of the 20x2, and I would like to have a 8x8 matrix, as the latest SID application supports them. Is there a modified frontpanel template with that setup? If not, I will edit the original one and provide the modification. http://ucapps.de/midibox_sid/mbsidv2_front.fpd
alchemist Posted May 21, 2014 Author Posted May 21, 2014 (edited) I will try something this evening. Edited May 21, 2014 by alchemist
alchemist Posted May 21, 2014 Author Posted May 21, 2014 Hello, I have tried this: The FPD is here: http://www.xaviermiller.be/images/MIDIboxSID/20140521/mbsidv2_xavier.fpd I will use a single plate for the 2 upper left panels. What do you think?
alchemist Posted May 30, 2014 Author Posted May 30, 2014 Hello, Can the surface be a little bit higher, so that I add 1 row of LEDs? Looking at the detailed photos, I think I can take more place:
alchemist Posted June 1, 2014 Author Posted June 1, 2014 Great! I will thus sighty raise the height of the control panel, so that the borders of the "function groups" will be again more aestethic :rolleyes:
