julianf Posted May 13, 2014 Posted May 13, 2014 I recently made a case for my own LXR drum machine (sonic potions) and two things have come to mind - a) people often ask me if i sell the 17" desktop enclosure for the panels i cut (i dont), and b) a case like the one below is simple enough to be adapted very easily Here's some photos of the case i made for the LXR - (screw holes in that last shot should have screws in them!) Here are my comments about the case - The wood on the sides is reclaimed oak, from a timber place close to me, that does fancy furniture made from reclaimed timbers (i live in an area where 200 year old beams are common place). I went for the square, machine drum, style look, rather than the sloped panel. I made a mock-up with a sloped panel first, but i did not think it looked as good. For such a small machine, im not sure that there is much ergonomic advantage, and i like that 'slab' look more! The panels are gloss black anodised aluminium, with silver engraving. The key caps fit the switches perfectly, and don't fall off : ) The allen bolts are A2 stainless, and will stay shiny. The logo is vectorised from this website. Maybe i should have added the LXR also, but i like the clean look and its contrast against the ancient oak. Im not set up for woodwork here - whilst i can make the odd thing, i dont have the tooling for multiple copies, but, if there was interest, the place that i got the wood from would make up the cases at a price, and i could cut the top and rear panels. So this is just a feeler. The costing would (i hope obviously) be multiples of a lazer cut plastic case - hand made with ancient hardwoods will never be comparable with plastics, but im guessing there may be some interest in quality? So...? note: i was not sure if this should be in bulk orders or the seq section?
widdly Posted May 14, 2014 Posted May 14, 2014 Yep I'd love one. I spent the weekend soldering up the front panel PCB for a midibox seq and was planning on ordering a set of your panels. A wooden case would be pimp! Also nice job on the LXR. I was just looking at it on the Sonic Potions site. The LXR is an awesome machine.
julianf Posted May 14, 2014 Author Posted May 14, 2014 The LXR is surprising nice. Although i built the electronics ages ago, ive only just started using it, now that its in a box. Im surprised by the range of sound, from smooth TR style hits, right through to FM ringing, to reduced sample rate crunches. And i have not even got into messing with the sample side of it yet. I think its a nice piece of work, (who's designer is still on the ball with the firmware). I reckon the minimum i can probably ask the wood place for is 5-off. The do custom furniture all the time, but, although all it is is a simple box, i think the price will just be too high on a single unit. I guess if there is even another couple of people interested, ill buy 5-off and keep 2 for stock. In hindsight, this thread probably should be in group buys? If a mod thinks similar, could it be moved?
