Posted (edited)
Hi
i m trying to finish my sequencer   (V3 , Ultracore+ 5 Banksticks-RAM ,4x IIC Midi ), but the BPM LEDs are still not working.
I'm using LED  from Liteon Type LTC4624  http://datasheet.octopart.com/LTC-4624B-Lite-On-datasheet-13706875.pdf
and i have made the following changes in the asm and have made a hex from it.
#define DEFAULT_BANKSTICK_MODE_CS0    2    ; 64k
#define DEFAULT_BANKSTICK_MODE_CS1    4    ; 64k
#define DEFAULT_BANKSTICK_MODE_CS2    5    ; Mixer Map (using CS2 to ensure compatibility with Atmel EEPROMs which only provide 4 CS addresses)
#define DEFAULT_BANKSTICK_MODE_CS3    1    ; Song mode (using CS3 to ensure compatibility with Atmel EEPROMs which only provide 4 CS addresses)
#define DEFAULT_BANKSTICK_MODE_CS4    1    ; 64k
#define DEFAULT_BANKSTICK_MODE_CS5    0    ; 64k
#define DEFAULT_BANKSTICK_MODE_CS6    0    ; 64k
#define DEFAULT_BANKSTICK_MODE_CS7    0    ; 64k
#define DEFAULT_BPM_DIGITS_ENABLED 2
#define DEFAULT_BPM_DIGITS_SEGMENTS    5
#define DEFAULT_BPM_DIGITS_COMMON    6
Everything is like in the documentation but its not working.
Has anybody a suggestion ´?
thanks
 Zossen
Edited by Zossen
the DEFAULT_BPM_DIGITS_* configuration looks correct for your hardware.
Could it be that the common lines are connected to the wrong Dx output pins?
I'm a bit unsure if it was (D7, D6, D5) or (D2, D1, D0)
