Minty Posted July 1, 2014 Posted July 1, 2014 (edited) Hello all. Please be gently, I'm a MIDI noob. My current setup is that I have a Boss GT8 guitar effects processor that has MIDI control, and a Hughes & Kettner Tubemeister 36 amplifier which is MIDI controlled. I have this set up so that the GT8 changes the amplifer channel to whatever I need when I change the 'patch' on the GT8. I need one more device to complete my setup; Basically, I need to add another analogue effect into the chain when in one of two amplifier channels, and remove it from the chain in the third. So in effect, a simple effects loop switch. I have attached a simple drawing of my idea on the concept, I just need to know how to make the midi part work and what components are required. [Edit] - it appears that the file didn't attach, maybe I need more posts on the forum to do that? It can be found here: Thanks! Edited July 1, 2014 by Minty
TK. Posted July 1, 2014 Posted July 1, 2014 Today MIDIbox is probably not the best choice for such a project, because the platform is designed for much more complex use cases. This Arduino based project seems to fit for your purposes: http://forum.arduino.cc/index.php?topic=73418.0 Adding the MIDI OUT shouldn't be a big deal. Either via software based forwarding, or via hardware (MIDI Thru circuit) Best Regards, Thorsten.
