sarnold Posted July 3, 2014 Posted July 3, 2014 Hi everybody, finally I found the time to start a project on my new LPC17 core. I want to replace my current MIDI router (PIC-based) with the MIDIbox NG application. I have MIDI devices connected to both IN/OUT ports and a computer via USB. All MIDI channels are used and need to be routed/duplicated to different ports. Here's my problem: MIDIbox NG offers only 16 router nodes, but I need at least 32 to route my channels properly. Is it somehow possible to increase the number of nodes? A different solution would be to offer a range of filtered source channels instead of single ones. E.g. could we somehow group these 5 nodes into a single one (without using "All")? ROUTER n= 1 src_port=IN1 src_chn=5 dst_port=OUT2 dst_chn=17 ROUTER n= 2 src_port=IN1 src_chn=6 dst_port=OUT2 dst_chn=17 ROUTER n= 3 src_port=IN1 src_chn=7 dst_port=OUT2 dst_chn=17 ROUTER n= 4 src_port=IN1 src_chn=8 dst_port=OUT2 dst_chn=17 ROUTER n= 5 src_port=IN1 src_chn=9 dst_port=OUT2 dst_chn=17 That would help me a lot.... Best, Sebastian
TK. Posted July 5, 2014 Posted July 5, 2014 Hi Sebastian, filter ranges will be more time consuming than processing more than 16 MIDI router nodes. The number could be increased in the mios32_config.h file, e.g.: #define MIDI_ROUTER_NUM_NODES 32 this requires to recompile the application. Do you know how to do this? Best Regards, Thorsten.
sarnold Posted July 6, 2014 Author Posted July 6, 2014 Hi Thorsten, thanks, that sounds like an easy solution. Recompiling shouldn't be a problem, I'll try it tomorrow. Best, Sebastian
