Hi!
When i try to compile the original Midibox NG app from the SVN then
i get the following error:
post-4098-0-50785700-1409282708_thumb.jp
First I suspected there is something wrong with my toolchain or system variables but
other MIOS32 apps compile without problems..
Maybe there is a bug in the actual SVN source?
Does anyone else get the same error message?
Best regards
Marxon
You've to update the complete repository, not only the application directory.
If this doesn't help, download the complete repository into a new directory (maybe you did some local changes?)
Hi Thorsten
Unfortunately this does not help.
EDIT:
I forgot to do a restart after i had changed the system variables.
Now it works!
Thanks a lot. :thumbsup:
Marxon
Edited by Marxon
