Hello,
What do you recommend to fix the PCBs in the box? What are the systems to place screw mounts on a plastic case?
What are the standard pieces to get (screws, mounts, ...)?
I am a really newbee in that hardware domain...
Kind regards,
Xavier.
Search "JB Weld" or "JBWeld" in the forum, it's a good way of fixing M3 metal hex spacers/standoffs to metal panels. Plastic is a bit different, the projects here often use Ponoko/Formulor cases that "samich" or compress together. In this way the components are PCB mount that makes things a lot easier.
