Hey,
i tried to follow the steps for the toolchain installation:
http://www.midibox.org/dokuwiki/doku.php?id=macos_mios32_toolchain_core
I got some problems while getting the files from the repository server.
With the command "mkdir svn" i made a new folder called "svn" but after typing "svn co svn://svnmios.midibox.org/mios32" the terminal starts to work but after it's finished, i cant see any folder inside the "svn" folder.
And after checking out, whether it would work with the command "cd $MIOS32_PATH/apps/tutorials/001_forwarding_midi" i get the error message: "No such file or directory"
Do you know what im doing wrong ?
I work with Yoesmite
best regards, sascha
Hey,
after updating the latest svn Version, i got another error message while trying to get the tutorial working...
it says: "Creating object file for app.c
make: arm-none-eabi-gcc: No such file or directory
make: *** [project_build/app.o] Error 1"
It seems that the PATH variable isn't set correctly.
The wiki page gives an example:
export PATH=$PATH:/usr/local/mios32_toolchain/bin
If you've copied the toolchain to another location (not /usr_local/mios32_toolchain, but somewhere else), just adapt this setting accordingly.
