Part # for Ethernet socket on LPC17 board
portervance
I'm hoping someone can point me in the direction of the correct ethernet port part to used with the LPC17 board on the SEQ4 project. I've purchased 2 ethernet sockets so far and neither has aligned properly to the PCB (the pin orientation is correct but some of the extra through-hole points do not align). I'm hoping to order the part via Digikey so I would appreciate if someone could point me to a specific correct part that they sell. Thank you!
It's a MagJack SI-60024-f - digikey #380-1117-ND
Make sure you get the right one - the pinouts can be pretty different on different eth jacks.  (edit: haha - rereading your post, I see you made the same mistake I did by ordering substitutes thinking the pinouts would be the same.  Mine fit the board, but I soon found out that even jacks with identical pin configurations can have different pinouts.  The SI-60024-f is the correct part.)
Edited by borfo
