I'm working on a controller for my guitar pedal board based on MIDIbox NG. I'm try to use a heavy modded Upper PCB from a Behringer BCR2000 for 8 enc with ledrings and several buttons. For now I have the Button Matrix sharing rows with the Led Matrix. It have reverse diode connection. With the Ledrings set by an ENC with CC <16 the Button matrix works, with CC > 16 the button matrix stop work only for the button line  connected with these ledrings. If I disconnect only the led row everything works fine with any ENC value.
Hope my description is clear, my english is very bad!
For now I know could be hardware problem but my first question is, it's possible to use Button Led Matrix with MIDIbox NG or I'm trying to do something that never work?
I've read several topics an there is one () speaking about a different problem with Matrix. I'm interesting in try an older version (1.031) for test but I cannot find it.
I attach my .NGC test file
Mattia
Hi Mattia,
please try v1.033_pre1 which is linked in this thread:
If the matrix is still not working properly, I need your .NGC file for further analysis.
There are no known problems with multiple button/LED matrices (with v1.033_pre1, there was a problem with v1.033)
Older versions can be found here: http://www.ucapps.de/mios32/backup/
But again: it's unlikely that the problem is related to the firmware itself.
thank you for the faster answer! Today I had try version 1.33pre1,2 and a older 1.32pre1 found in another topic. I not try with inverted DIN order, tomorrow I'll check.
Thank you,
Mattia
This is my .NGC file:
RESET_HW
#SCHEDA 1
#Encoder MAP
ENC n=  1   sr=3 pins=2:3   type=non_detented
ENC n=  2   sr=3 pins=0:1   type=non_detented
ENC n=  3   sr=3 pins=4:5   type=non_detented
ENC n=  4   sr=3 pins=6:7   type=non_detented
ENC n=  5   sr=2 pins=2:3   type=non_detented
ENC n=  6   sr=2 pins=0:1   type=non_detented
ENC n=  7   sr=2 pins=4:5   type=non_detented
ENC n=  8   sr=2 pins=6:7   type=non_detented
# Encoder events
EVENT_ENC id= 1  fwd_id=LED_MATRIX:1   fwd_to_lcd=1  type=CC chn= 1 cc= 16  label="Gain        %3d@(1:1:2)%B"
EVENT_ENC id= 2  fwd_id=LED_MATRIX:2   fwd_to_lcd=1  type=CC chn= 1 cc= 17  label="Tone        %3d@(1:2:2)%B"
EVENT_ENC id= 3  fwd_id=LED_MATRIX:3   fwd_to_lcd=1  type=CC chn= 1 cc= 18  label="Volume      %3d@(1:3:2)%B"
EVENT_ENC id= 4  fwd_id=LED_MATRIX:4   fwd_to_lcd=1  type=CC chn= 1 cc= 19  label="Reverb      %3d@(1:4:2)%B"
EVENT_ENC id= 5  fwd_id=LED_MATRIX:5   fwd_to_lcd=1  type=CC chn= 1 cc= 20  label="Time        %3d@(1:5:2)%B"
EVENT_ENC id= 6  fwd_id=LED_MATRIX:6   fwd_to_lcd=1  type=CC chn= 1 cc= 21  label="Feedback    %3d@(1:6:2)%B"
EVENT_ENC id= 7  fwd_id=LED_MATRIX:7   fwd_to_lcd=1  type=CC chn= 1 cc= 22  label="ToneRepeat  %3d@(1:7:2)%B"
EVENT_ENC id= 8  fwd_id=LED_MATRIX:8   fwd_to_lcd=1  type=CC chn= 1 cc= 23  label="Mix         %3d@(1:8:2)%B"
# LEDring-7digits Buttons configuration
DIN_MATRIX  n=1   rows=16  sr_dout_sel1=1  sr_din1=1  inverted_row=1  inverted_sel=1   mirrored_row=0             button_emu_id_offset=1001
DOUT_MATRIX n=1   rows=16  sr_dout_sel1=1  sr_dout_sel2=2  sr_dout_r1=4  sr_dout_r2=3 inverted_row=1 inverted_sel=1  led_emu_id_offset=1001
# modified ledring patterns for 16 LEDs
# LED_MATRIX_PATTERNs
LED_MATRIX_PATTERN n= 1  pos= 0  pattern=1000000000000000
LED_MATRIX_PATTERN n= 1  pos= 1  pattern=1100000000000000
LED_MATRIX_PATTERN n= 1  pos= 2  pattern=1110000000000000
LED_MATRIX_PATTERN n= 1  pos= 3  pattern=1111000000000000
LED_MATRIX_PATTERN n= 1  pos= 4  pattern=1111100000000000
LED_MATRIX_PATTERN n= 1  pos= 5  pattern=1111110000000000
LED_MATRIX_PATTERN n= 1  pos= 6  pattern=1111111000000000
LED_MATRIX_PATTERN n= 1  pos= 7  pattern=1111111100000000
LED_MATRIX_PATTERN n= 1  pos= M  pattern=1111111110000000
LED_MATRIX_PATTERN n= 1  pos= 8  pattern=1111111110000000
LED_MATRIX_PATTERN n= 1  pos= 9  pattern=1111111111000000
LED_MATRIX_PATTERN n= 1  pos=10  pattern=1111111111100000
LED_MATRIX_PATTERN n= 1  pos=11  pattern=1111111111110000
LED_MATRIX_PATTERN n= 1  pos=12  pattern=1111111111111000
LED_MATRIX_PATTERN n= 1  pos=13  pattern=1111111111111100
LED_MATRIX_PATTERN n= 1  pos=14  pattern=1111111111111110
LED_MATRIX_PATTERN n= 1  pos=15  pattern=1111111111111111
#7segments Display
EVENT_LED_MATRIX id=9   fwd_id=LED_MATRIX:10  led_matrix_pattern=Digit1
EVENT_LED_MATRIX id=10  fwd_id=LED_MATRIX:11  led_matrix_pattern=Digit2
EVENT_LED_MATRIX id=11                        led_matrix_pattern=Digit3
#buttons rows
EVENT_BUTTON id=1001 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 01:01 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1002 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 02:02 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1003 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 03:03 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1009 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 09:09 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1010 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 10:10 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1011 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 11:11 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1017 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 17:17 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1018 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 18:18 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1019 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 19:19 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1025 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 25:25 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1026 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 26:26 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1027 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 27:27 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1033 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 33:33 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1034 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 34:34 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1035 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 35:35 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1041 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 41:41 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1042 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 42:42 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1043 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 43:43 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1049 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 49:49 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1050 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 50:50 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1051 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 51:51 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1057 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 57:57 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1058 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 58:58 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1059 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 59:59 lcd_pos=1:4:2 label="%d"
#next 4 rows
EVENT_BUTTON id=1004 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 04:04 lcd_pos=1:4:2 label="%2d"
EVENT_BUTTON id=1012 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 12:12 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1020 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 20:20 lcd_pos=1:4:2 label="%d"
EVENT_BUTTON id=1028 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 28:28 lcd_pos=1:4:2 label="%d"
#OUTPUT LEDS
EVENT_BUTTON id=1001 fwd_id=LED:1194 range= 01:01 radio_group=1
EVENT_BUTTON id=1002 fwd_id=LED:1195 range= 02:02 radio_group=1
EVENT_BUTTON id=1003 fwd_id=LED:1196 range= 03:03 radio_group=1
EVENT_BUTTON id=1009 fwd_id=LED:1197 range= 09:09 radio_group=1
EVENT_BUTTON id=1010 fwd_id=LED:1198 range= 10:10 radio_group=1
EVENT_BUTTON id=1011 fwd_id=LED:1199 range= 11:11 radio_group=1
EVENT_BUTTON id=1017 fwd_id=LED:1200 range= 17:17 radio_group=1
EVENT_BUTTON id=1018 fwd_id=LED:1193 range= 18:18 radio_group=1
EVENT_BUTTON id=1004 fwd_id=LED:1210 range= 04:04 radio_group=1
EVENT_BUTTON id=1012 fwd_id=LED:1211 range= 12:12 radio_group=1
EVENT_BUTTON id=1020 fwd_id=LED:1212 range= 20:20 radio_group=1
EVENT_BUTTON id=1028 fwd_id=LED:1213 range= 28:28 radio_group=1
Ok,
I have retry version 1.33pre1. The problem is still there. So now I will check my board because the behringer was cabled very different and could be there is a short that I've not found.
Thank you so much for help!
Mattia
