kuykens Posted January 17, 2015 Posted January 17, 2015 HI All, I have been struggling some days with getting the programming environment in place. I have followed the instructions on setting up the toolchain according to: http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core I have installed MIOS32 from SVN in : C:\Users\jillejille\Documents\MIOS32\trunk If I open a command window on one of the tutorial projects: C:\Users\jillejille\Documents\MIOS32\trunk\apps\tutorials\001_forwarding_midi and do a make the utility ends up in an endless loop not displaying anything. If I start make with -d switch I get endless lines of debug info. A snippet of that output is included below: Trying pattern rule with stem `freertos_heap.d'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.p'. Looking for a rule with intermediate file `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.p'. Avoiding implicit rule recursion. Avoiding implicit rule recursion. Trying pattern rule with stem `freertos_heap.d'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.web'. Trying pattern rule with stem `freertos_heap.d.p'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.p,v'. Trying pattern rule with stem `freertos_heap.d.p'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/RCS/freertos_heap.d.p,v'. Trying pattern rule with stem `freertos_heap.d.p'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/RCS/freertos_heap.d.p'. Trying pattern rule with stem `freertos_heap.d.p'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/s.freertos_heap.d.p'. Trying pattern rule with stem `freertos_heap.d.p'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/SCCS/s.freertos_heap.d.p'. Trying pattern rule with stem `freertos_heap.d'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.web'. Looking for a rule with intermediate file `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.web'. Avoiding implicit rule recursion. Avoiding implicit rule recursion. Avoiding implicit rule recursion. Trying pattern rule with stem `freertos_heap.d.web'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/freertos_heap.d.web,v'. Trying pattern rule with stem `freertos_heap.d.web'. Trying implicit prerequisite `project_build//C/Users/jillejille/Documents/MIOS32/trunk/programming_models/traditional/RCS/freertos_heap.d.web,v'. Environment variables are set up as follows: MIOS32_BIN_PATH=C:\Users\jillejille\Documents\MIOS32\trunk\bin MIOS32_BOARD=MBHP_CORE_LPC17 MIOS32_FAMILY=LPC17xx MIOS32_GCC_PREFIX=arm-none-eabi MIOS32_LCD=universal MIOS32_PATH=/C/Users/jillejille/Documents/MIOS32/trunk MIOS32_PROCESSOR=LPC1769 Path is setup as: Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32 \WindowsPowerShell\v1.0\;C:\MSYS\1.0\bin;c:\mios32_toolchain\bin;C:\Program File s\TortoiseSVN\bin;C:\Program Files\Microchip\xc8\v1.33\bin This runs on a 32 bits Win7 machine Any pointers how to solve this would be welcome... regards Hans
TK. Posted January 17, 2015 Posted January 17, 2015 Nobody reported such an issue before, therefore I've no spontaneous idea what could cause this. The environment variables look ok. Are you trying this with an unmodified SVN repository? (I guess: yes, of course...) It seems that the programming_models/traditional/freertos_heap.cpp file is problematic... but why? Best Regards, Thorsten.
kuykens Posted January 18, 2015 Author Posted January 18, 2015 Well this snippet was of a file that grew to 700k (!) in a few seconds. I was unable to upload it to the topic. Almost all files create the same problem in the logging. Indeed no modifications in the SVN download. The make file test also succeeded, so no conflict in make tooling. The computer also is a relatively clean system. I had delayed my endeavors to solve this myself until I got message from you. Guess I have to pick it up again and see whether this is solvable. Such a pity.
kuykens Posted January 18, 2015 Author Posted January 18, 2015 Thorsten, Got it working at last. I had an additional space in the tool chain folder. After fixing that I still needed to do an addiotnal export of the SVN tree to roll back modifications I did to the make environment. Then, it worked.
